DIY Powder Coating
Results 1 to 10 of 10
DIY Powder Coating
    21' Liberator Jet NORDIC454's Avatar
    BIG D
    Default DIY Powder Coating
    I've got some aluminum parts that I'm gonna try to PC myself. My Grandpa has PC rig from eastwood and oven in the garage. I know the parts have to be very clean. Any advice would be great as I have never tried this before.
    Thanks in advance.
    Kingman/Golden Vly, Az
    Quote Originally Posted by NORDIC454 View Post
    Thanks in advance.
    just follow the instructions from Eastwood & u will be fine...bakeing in the oven is the key
    FastRat
    Colfax, Ca
    I found that you need the piece to be VERY clean. A light touch with a tack rag before you spray. The tiniest bit of dust will show.
    If you make a mistake you can touch it up. Word of caution use the air pressure recommended or you will have the power everywhere. Make some kind of hanger so you wont have prints all over it. Be sure you have the switch on when putting on or the powder wont stick. I would put the power on outside the garage, house, etc, or it will be everywhere.
    you will have a ball, have fun.
    Avondale,AZ.
    Thoroughly degrease the parts BEFORE blasting, then again after, all cast parts such as carb parts and all jet parts need to be cooked at the cure temp for an hour, then cooled before applying the powder, this allows all trapped impurities to outgas before the powder is applied. The lack of outgas cooking prior to coating is why some parts have small blisters in the coating. Practice on other same type of old parts before attempting to coat the good ones, chemical stripping will cost you more than you saved by doing the job yourself if you screw it up. and everybody screws one up once in a while. Bead blasting takes forever to strip powder coat. TIMINATOR
    Senior Member wajetboy's Avatar
    Auburn, WA
    i would degrease, blast, clean again with denatured alcohol, outgas any aluminum or cast parts at 50 degrees hotter then cure temp for 45-60 mins, let cool and spray. make sure you have a good ground on your parts or else your powder will not stick also make sure that the outlet that you are using is wired correct. does your gun have a kv adjustment? if you have anymore questions let me know.
    here is some stuff i did a couple days ago
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    BIG D
    Default Thanks
    Thanks for all the replies, bout to go out in the shop and set up right now.
    Auburn, WA
    good luck let us know how it goes
    BIG D
    Default Thanks
    Parts came out nice, thanks for all the help.
    Auburn, WA
    looks great nice job.
