Spark Problems.. (msd haters avoid)
Results 1 to 14 of 61
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Spark Problems.. (msd haters avoid)
    weird issue, just got the motor back in the boat tried to start it and nothing. My setup is a MSD 6AL box, Blaster2 Coil, Pro-Billet Marine Dist. The cap and rotor have one weekend on them and a few driveway runs. MSD unit looks to be getting power, if i take my timming light and clamp it to #1 i get nothing. If i take the timming light and clamp it to the coil wire that runs to the dist the light blinks like crazy. So to me i'm getting spark to the cap but from there i'm having a problem. Pulled the cap used alittle emory cloth and cleaned up terminals on rotor and cap, same problem. Actually whats weird is when i was clamped to #1 i got one spark out of it (one blink on the light) and then nothing. I clamped one other wire and same deal. My thinking is my cap or rotor is bad but how, it's so simple and even if there was a break in a term the spark is powerful enough to jump and i should still see somthing. Any Ideas?
    Senior Member BA Kurtis's Avatar
    I had problems just like this with the same set up very frustrating, what mine wound up being was the magnetic pick up was bad in a bran new distributer, so try replacing it and see what happens, a $20 part might solve your problem. When MSD works it works great but when it dont its hard to track down the problem. Good luck with it
    B1 Racing cs19's Avatar
    Default Msd Hater
    I Hate Msd, You Should Change To Crane Fireball
    B1Racing.net
    Ladera Ranch
    Go over your install again and make sure everything is the way it should be. Check your grounds. I assume its turning over so battery charge is good?
    Sounds like Dan might be on to something. Id call MSD and see if they can send you one free of charge, tell them you tried a friends and it worked... or order one from your favorite supplier.
    Second that
    Check your coil wire going into the cap
    Default Fireball hater
    Second that
    I was just joking around, Crane blows you should switch to MSD.
    B1Racing.net
    You were smarter than you thought you were.
    When using the new style MSD caps and rotors, be sure to check the rotor tab. The tabs are creating strange problems, arcing, and burning the carbon buttons out, off the cap.Make sure the rotor tab pushes the distributor cap off the base, or it's gonna give you some problems.
    I thought the MSD Marine distrbutor only worked with the 6m-2 marine box?.
    Quote Originally Posted by Moose View Post
    A conector change or adapter cable is all thats needed.
    get a magneto problem solved
    B1Racing.net
    TEN THIRTY ONE RCB19's Avatar
    I agree!
    RCB
    San Clemente, Ca
    Quote Originally Posted by BA Kurtis View Post
    Dont think it's that, when timming light is hooked to the cable between coil and dist the light will blink like crazy when turing the motor. If i disconnect the connection to the distributor (magnetic pickup lines) this doesnt happen. So this tells me that the magnetic pickup is working ok.
