What size carb?
Results 1 to 14 of 14
What size carb?
    Southwest corner AR
    Default What size carb?
    What would be the best size Holley carb for a stock 454 BBC peanut port heads with an cheap air gap intake? Double pumper only! 650,750,850? This is on a jet boat. WT
    WT
    WFL Crew!!!
    750 not to big, not to small
    whatya building now coby?
    Southwest corner AR
    Im looking at a new boat,you know one of those Youngbloods and plan on pulling my 496 to put in it! I have two motors to choose from one stock and one well warmed over 468 to go back in my Spectra! Trying to deside what would be best! 750 is what I thought but if I go to change anything the 850 might be better.
    WT
    WFL Crew!!!
    tx18 or tx19?
    Southwest corner AR
    Tx 19
    WT
    WFL Crew!!!
    Iuka, Mississippi 38852
    go with the 850 and nothing but holley. sooner or later you`ll wish you had. i`m running a tx 19 for a lake boat that i`ve owned since 1982. if theres a better lake hull i don`t know what it is.
    Southwest corner AR
    Been looking for a long time! I think I have found one to get wet with! WT
    WT
    WFL Crew!!!
    The Right Coast/SE-PA
    Quote Originally Posted by Richard Till View Post
    go with the 850 and nothing but holley. sooner or later you`ll wish you had....
    If I may ask...
    850 DP list #9380 w/annular discharge boosters
    4-corner square jetting.
    On a 468 10:1 compression spining just over 5K
    78 jets front and back and I tried 80's-82's
    Problem...the thing falls on its face like there's a rag over the intake?
    The carb is spotless and free from debris in all ports.
    Senior Member sleekvino's Avatar
    750 plenty for a stock chevy
    PORNO RACING INC WHERE ITS "HARD" TO WIN
    Feb 2009
    SF Bay Area
    hammerdown, 80 80 should be good for that motor. Teague likes these carbs because of the soft progressive secondary, gets rid of the lean spot just before the secondaries open. something is wrong if it lays down though.
    HammerDown, are the accelerator pump squirters giving a good shot throughout their range? whats your timming setting. i like the 80/80 jets too but you`re not far enough off to be causing problems. how bout the power valve? fuel pressure? when you rule out all of these potential problems, i`d say its back off and to the work bench.
    Senior Member W.O.T's Avatar
    Campo Ca
    Get a 750 Holly mechanical secondaries. jet it correctly your good to go. put a motor together mild build 454 with a 750 vacuum carb jetted up and it runs like a dream. i wouldnt run a vacuum carb but just sayin 750 is enough for a pretty stout and mild 454.
    Tx 19
    bout phucking time
    Annular boosters are great, however a handful to tune, it just takes time and patience.
