Nos and A/F gauges-#'s
Results 1 to 10 of 10
    Default Nos and A/F gauges-#'s
    I'm a little hesitant to spray, since 2005, I've gone through 3 boat motors.lol I used to think that the main way to go wrong(with nos) was to be too lean. A few months a go there was a thread that said too rich was just as bad. I have a set of dry headers and a wideband and was wondering if the std. a/f #'s would apply when the nos was on, or not???? I realize there are a lot of other variables(timing ect). For argument/discussion sake here lets say it's a 200 shot.
    I'm a little hesitant to spray, since 2005, I've gone through 3 boat motors.lol .
    Did they die because of Nos? If so what type of system, plate or fogger?
    S CP
    S CP
    Naw....never sprayed before. Killed the 1st motor before I made my 1st pmt on the boat.lol The guy that sold it to me said it was "around" 11 to 1, turned out to be closer to 12 to 1. Personally I think I got some bad gas because I was mixing 110 and still burned a hole between 5 an 7 in the cyl. head big enough to stick your pinky finger in. The second motor went about a year and a half,long story short I lost a cam lobe and lifter.
    From all my Nos system reading and books I don't recall the answer, but I don't think the A/F numbers change all that much. Cyclone or CS may have dyno sheets showing this when they get back from the Regatta maybe they'll pipe in.
    I have a dyno sheet from a guy's engine I'll see if the A/F #'s were about the same.
    Edit: The 528" Ford made 825 hp at 6,600 with a BSFC of .397 with an A/F of 12.67
    on the Nos it made 1,145 hp at 6,400 with a BSFC of .394 with an A/F of 11.32 I can't tell you if that number is typical. I'll look in some of my Nos books when I get a chance.
    S CP
    S CP
    Thanks, I didn't know if there was a different ideal # to shoot for or not. I wondered if the extra 02 in the nos would maybe show a false lean? Based on the #'s you've posted, I'd guess probably not. Maybe I'll ask over on the bullet and prepare for the beating.lol Anyone have any thoughts on on whether or not a pyrometer would help tell if you were about to melt chit? Or do you think it would happen to fast to show up on the meter? Sorry if I'm beating a dead horse here, I'd feel better if I could see via some type of gauge if my motor was or wasn't getting abused. Or if I did, or didn't have it set up right.
    Anyone have any thoughts on on whether or not a pyrometer would help tell if you were about to melt chit? Or do you think it would happen to fast to show up on the meter? .
    Been there done that.....16 yrs ago. Shit happens way to fast.
    Just get a good system and try it. No need to reinvent the wheel.
    S CP
    look for around 12ish on the a/f ratio, anything more than that on nitrous is getting alil fat, or it is at my altitude anyways(think i'm 500ft above sea level) and that's where my gullwing like to be with the 505 on the 450hp shot. basically shooting for almost the same a/f ratios the blown/boosted guys.
    Newton Ks.
    As long as you are burning the same fuel (ie, gasoline), the same mixture ratio needs aply.
    The "extra" oxygen is countered by extra fuel, maintaining balance.
    An O2 sensor, obviously, reads un-burned O2, and the only way you get more un-burned O2 is to not counter it (the additional from the N2O) with additional fuel.
    H.L. Mencken
    B1 Racing cs19's Avatar
    Ask 10 different people and youll get 10 different answers on this one. Some say shoot for high 11s on the bottle, some say its the same as off the bottle. Saw some stuff recently on a dyno where 12.5 was targeted and the plug readings were real nice.
    Chris.
    B1Racing.net
    Lost Wages, NV
    Typically, I shoot for 1/2 point richer A/F on the squeeze than off. In a N/A motor, that's normally 12.8-13:1 on the motor, then 1/2 point richer on the squeeze. If its forced induction, then 11.5-11.8:1 minus the 1/2 point.
    Keith-
