Oil Pressure drops as RPMs increase ?
Results 1 to 14 of 93
    Okmulgee Okla.
    Default Oil Pressure drops as RPMs increase ?
    What could be causing this? I don't think it's loading 10 qts of oil in the top. Let off the gas and pres. returns to 70 in the time it takes the motor to idle down. Has this happened to anyone? and how did you fix it? New 496 With HV pump, mech oil pres guage on motor, electric guage in dash, so I know its not the guage.
    Thanks in advance
    Don
    well the block is GM any ways
    IS UNDER FIRE
    Redding, CA
    The only time my engine did that, the oil pick up was cracked at the entry point of the PU screen. (Milidon)
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Default Remote filter?
    If the remote filter is plumbed backwards it will also do that........Flappers closing at higher Rs..........Ray
    LOUD BOATS SAVE LIVES
    Quote Originally Posted by Wild Hair View Post
    Thanks in advance
    Don
    Maybe too much oil in the pan...windage...crank aerating the oil. Just my $0.02.
    Either way it's a sign that the oil pump is cavitating.
    just went thru this, if you're pickup tube is fine, and the cooler is plumbed correctly, its teh oil pan. most milodon type pans don't have the rear tray and the oil can climb the back of the oil pan, crank hits it and poof, oil pressre dives. what kinda oil pan ya got on there????
    fyi, hamburger makes a nice cheap oil pan kit for 200 bucks for a jetboat
    Okmulgee Okla.
    Default ?
    Flappers ? where the hell do they put flappers? I have a dual remote system on this thing. Had the same system on a previous motor and never had a problem. Running Fram HP1 filters with an 8qt truck pan at 1/2 qt over full to compensate for the oil dumped up top. Have restrictors ordered but not instaled. I'll switch the lines today and see what happens tomorrow after work. But with my luck it can't be that simple. If it is IOU a beer or 30, will let you know tomorrow. Thanks everyone for your input.
    IS UNDER FIRE
    Could also be the pick up is too close or too far from the bottom of the pan. Forget the extra half quart and try seven in the pan. You might be surprised.
    Okmulgee Okla.
    Strange how identical setups on two different motors can act so different.
    will switch hoses and see what happens, then I'll check pickup if that dont work.
    IS UNDER FIRE
    Atlantic Beach, FL
    Uh, hello? It IS a boat!
    DFW Texas
    I agree with steelcomp . Mesure your pickup with the pan , Sounda like you on the bottom and pulling the pan up on a vacume
    Don't discount that you're running too much oil. Most pans will work better with less oil than more.
    Senior Member Chris The Plumber's Avatar
    Sep 2008
    Chandler
    Default Oil press.
    Had it happen to me, oil pump pick-up was too close to the bottom of the pan, it was 1/4" & I changed it to 5/8" & problem solved. some of the cheaper pans can & will flex if the pick up is too close.
    Kachina Condor Tunnel hull
    Hondo Hydro pickle fork, dominator pump.
    Hondo Jet blown540's Avatar
    Holland, Mi
    A collapsed Fram oil filter did it to me!........KISS
    Wet
    Wet is offline
    East Hampton, CT
    Why is this sounding like an Olds motor?
    Go with 7 quarts, and ditch the Fram crap. Go with anything but.
