Carb Size calculator for SC?
Results 1 to 14 of 15
    These colors don't run BLWN BUX's Avatar
    Sep 2008
    Riverside, CA
    Default Carb Size calculator for SC?
    Hi,
    I am new here so please forgiv if this is a redundent question.
    I bought a 22' Placecraft deck/Cat with a 540CI whipple charged set up.
    I an not sure if the enging combo is what it could be.
    I think my carb may be too small. It dynoed 668 HP at 5600RPM @ 6# boost.
    I looked up a carb chart formula and this is what I found
    CI / 1728 X RMP / 2 = "Carb Size for N/A at 100% VE"
    Turbo/ SC applications need a multiplier added as well:
    14.7 + boost PSI / 14.7 = "Multiplier ratio"
    For example:
    I run a 540CI @ 5# boost at 5400 RPM
    540 / 1728 X 5400 / 2 X 1.34 = "1122 CFM carb needed"
    Is this a good formula for carb sizing?
    If so then I think my carb size is too small. I have a Demon (like holy 4150). I think these carbs only go up to like 850 CFM?
    I was thinking about changing blower pullies for more boost; but I am thinking that just going to a bigger carb would probably increase boost on top end by itself.
    Any help would be appreciated
    Chad
    i'd stay 4150 if you can, you're not gonna like the fuel mileage of a dominator carb. check out some custom carb shops and see if you can find a nice custom 4150 that'll flow over 1000cfm, call it good
    Kingman/Golden Vly, Az
    check out the parts forum...there was a few Holley 950's & a 1000cfm carb for sale...might be what ur looking for...just trying to help
    FastRat
    Sep 2008
    Riverside, CA
    I would think that any carburetor that is tuned properly would give equivlent fuel milage.
    If A/F ratios are maintained then there should be no change in fuel usage. Yes?
    Sombody can correct me here, I have NO experience with 4500's
    I am preaty good about tuning though, I am an EFI guy after tuning my Corvette folowing many changes.
    This is also a Jet Drive (I don't know if that is relative)
    Sep 2008
    Riverside, CA
    So, if I increase boost to 8-9# and will be running 5600-5800 then I would need about 1350 CFM Carb(s)?
    This Whipple only has one carb flange
    we're trying to tell you to replace the current carb with a holley 4150 1000cfm or bigger, they make em you better be carefull if that thing is a outdrive and you're gonna increase boost, some outdrive's don't like that
    Sep 2008
    Riverside, CA
    Its a jet drive with an "A cut" impellar.
    Senior Member 4CE FED's Avatar
    Whipple 2.3 or 3.3? ...hope it's not a 2.3 on a 540.
    My 3.3 is a dominator style flange, I think they made either.
    The more I jetted my 1095 demon up, the faster it went, and
    that was only on a stock 502.
    Get an A/F meter first!
    If you have a 3.3 on a 540, I think you will make more power with bigger carb. What's the rest of your fuel system?
    I also know where there is an Accel DFI setup, PM for phone#
    {(cid X rpm)/3456} X {(BOOST/14.7)+1}
    {(540 X 5400)/3456} X {(5/14.7)+1}
    2916000/3456 X .3401 + 1
    843.75 X 1.3041=
    1100.25 You are short, and formula is soft. Anything less, and you are going to have a hard time hitting you boost numbers with the recommended pulleys for that boost. Your choking the blower.
    Sep 2008
    Riverside, CA
    Quote Originally Posted by 4CE FED View Post
    I think its a 2.3 (Will have to confirm, boats ate the river storage now)
    I spoke with Whipple today and they said that the 3.3 would say 3300 on the side. I don't recall anything except whipplechaged on mine.
    Whipple told me that I should run a 1050 Dom and can expect about 10# max.
    I would think that I can use a detailed 4150 Carb as recomended by the other guys here.
    I have large fuel lines, and maintain about 9 psi FP under load.
    I have FP guage on dash so monitoring is easy
    Sep 2008
    Riverside, CA
    843.75 X 1.3041=
    Is what i thought also
    TNKS
    sacramento
    Quote Originally Posted by BLWN BUX View Post
    TNKS
    i ran a twin turbo with a 850 holley draw through set-up & gained 4mph just by putting on a 1150 dominator i.e. the bigger the straw the easier to suck through, .
    Somewhere between Paso & L.A.
    I've got a 1000cfm annular discharge 4150 on a stock 502/2.3 whipple
    in a 25' warlock cat, has made best of 6lbs @5400/ 96mph gps.
    IMO, you need a bigger carb!
    i'm back!! 1QuickCP's Avatar
    Montana
    Yup 4500 dominator for sure...try a 9375 or 9377 ..should work great when dialed in. oh and change linkage to full progressive for much better fuel mileage and drivability
