Flat tappet lifters.
Results 1 to 14 of 75
    Cantard 71hallett's Avatar
    snow bank
    Default Flat tappet lifters.
    What are the best flat tapet hyd. lifters you can buy?
    Senior Member The Violater's Avatar
    Rhodes ? Are they still around ? They used to be the whip set up.............
    / The Few The Proud TheBlown
    Anything better than the ones you're using.
    Rhodes lifters were popular, but relly more of a gimmic than anything. All they really were was out of spec lifters that someone found a niche for and capitalized on with some good marketing. Thing is, under the right conditions, they actually worked!
    Solids....I'm just sayin
    snow bank
    Doing a Stocker engine. Rules are hyd. lifters 450 lift max. Lifters I have now (Crane) are bleeding off on me.
    Ewww...that's gotta be messy!
    snow bank
    Yes SIR.
    I'm having good results with the Comp Cams Pro Magnum lifters. They have a retaining plate instead of a clip...it WILL NOT come out.
    However, you only preload them 0.002-0.004" (zero to 1/8 turn) according to Comp Cams instructions. From this I'm guessing that they're an anti pump up design.
    Since when did solids have anything to do with hydraulic lifters? RTFQ!
    PASO ROBLES CA cougar63's Avatar
    PASO ROBLES
    Crower i believe i have a couple new sets from ss engine .also have studded block ,crank and brand new pistons and rods for ss set up apba stamped
    Oh.. I have to give Paul a hard time every now and then....rtfq?
    cfm
    cfm is offline
    AC Delco P/N 5232720. This is the GM/Delphi hyd lifter with the 'hard iron base'. It looks like a two piece. Pretty much the best in regards to not wearing out like the other aftermarket and/or import lifters and can run to 7k (small block chevy) if you use 1/8 to no more than 1/4 turn pre-load.
    Can get these from any GMPP dealer like here: http://www.sdparts.com/product/52327...licLifter.aspx
    snow bank
    It,s all good....I give him a hard time too. lol
    okie, lake Texoma
    You know,-- you "can" run solid lifters on a hydraulic cam. just never try to do it viseversa.
    Dirt trackers do it all the time in classes that require you to run a hydraulic stick.
