This is going to max out the dumb-o meter but??
Results 1 to 14 of 15
    Default This is going to max out the dumb-o meter but??
    Is there such a thing as a closed chamber after market bbc cylinder head.
    Edelbrock has a 110cc "sort of" closed chamber, and the GMPP ROval (which is basically the same head)
    What would 8 or 9 cc's do to a compression ratio???? I'm guessin not that much .5??
    El Cajon, Ca.
    Typically... on a 454/468 type app.. going from open chambers to closed chambers... about 12cc will get you about a point of compression.
    The Bostick®
    Chico, Ca
    i did some quick numbers on my 502 i'm building which will have about 8.75:1 but if i drop 8cc on the heads and everything else is the same it jumps the compression up to about 9.35:1. the ratio of how much a cc will change the compression will differ with different cubic inches also (if i'm not mistaken)
    AP
    They also have one that is 100 cc:
    PERFORMER HIGH-COMPRESSION 454-O
    100cc semi-open chamber heads feature a 1-1/2° rolled over (angle milled) design that improves intake port alignment and provides a smaller combustion chamber without shrouding the valves
    9.2:1 compression with flat-top pistons for an outstanding high performance street head
    8.8:1 compression ratio when used on 1987-up TBI-equipped 7.4L dished piston motors
    Produced over 450 ft/lbs. torque when combined with our Multi-Point EFI System
    Chamber Size Intake Port Size Valve Sizes (in/ex) Bare (single) Complete (single)
    100cc 290cc 2.19"/1.88" #60489 #60499
    Note: See the Cylinder Heads Chart for specs. Mark IV rocker arms and valvetrain parts required.
    Cantard 71hallett's Avatar
    snow bank
    OHH its Maxed!!
    On my 434 with the 124 cc heads its 8.2
    With the 100 cc heads its 10.0 ish...you can also pick up a little with the head gaskets.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    brodix offers closed chambered heads,angle milled.look on there website some of the best heads in the world.
    the general rule of thumb is for every 10cc that is close to 1 point in compression.
    Yeah it's called a BLOWER
    #55
    My bad...I meant 100cc...thanks for the clarification.
    Too bad those runners are too small for me...
    The problem with the late replacement (vortec?)100cc Eddy head is it is a little shrouded in the chamber. Not as much as a GM closed chamber, but it does impeed(sp) flow. I had a talk with Steel about this head awhile back, and is to bad that some one hasn't built a head with a oval, roval port where the roof is where the rect head roof is. the Eddy vortec head has quite a bit of roof above the port, and it can be raised quite a bit before breaking into the rocker area. Not quite as big a rect, but a lot better than as cast. The other problem with them is that there no pistons other than flat tops that will work with them. Even regular roval 110cc and rect 118cc Eddys and GM signature heads require a dedicated head if it has a dome. SRP small domes work, and JE has a couple of Eddy hi compression pistons, but niether will work with the vortec Eddy. So now you need a custom slug. I have kick this head around alot, and someday I may give it a go. I am amazed someone like Dr. J hasn't maxed out a set of those.
    Senior Member CK7684's Avatar
    Minnesota
    I've got domed pistons with my Edelbrock RPM oval port heads...
    Go back and read my post. Yes, there are Eddy compatable domed pistons out there. SRPs small dome is one. But the don't work with the 100cc vortec Eddy head.
