well more 468 issues, arhhhhhhhhhhh
Results 1 to 14 of 15
    Default well more 468 issues, arhhhhhhhhhhh
    well i got my heads back friday and the machine shop couldn't find anything wrong with the rh head, even though i know i saw #6 shoot alil water out when i water pressure tested the motor, also #7 shot out some. well he said he found a exhaust guide leaking on #7, fixed that but couldn't find anything wrong with the other head. so i get home friday, wait for it cool down, go out and start cleaning up the block to slap heads back on, on the rh i see that #6 has a thin sleeve in it, immediately i know where the water got into the cylinder at. rotated the motor till the piston was down, and sho nuff, a 6in crack in the bottom of the sleeve when the block got air exposed, rust highlighted the crack for me, never saw it the prior weekend when i took the heads off. i had my 10yr old yank the shortblock back outta the boat and once he had it hanging , we stuck it on a stand and busted the block down. found that the bottom end was fully balanced had arp waveloc rod bolts on dimple rods, with forged 10.5 to 1 pistons(which still look new). not sure but the crank looks to have been nitrated, cause its black, but the p# on it show's to be 454 cast anyways, someone knifed the throws and did a shitload of work to a cast crank. i've got the block in my blazer, i'll send it over for a thick sleeve after lunch cool the bottom end is balanced though!
    The Man cordog009's Avatar
    East Texas
    Well atleast you found out the culprit..still got all week to get it back together for the weekend.
    1984 Youngblood TX-19 SOLD
    mo money mo money i'm goin thru the pump this week while the block is out, putting in a uwr and bc cut impellor, stuffer, new seals/bushings/thrust bearing. may as well make the pump new and fresh since i'm now overhauling the motor
    East Texas
    Yep..I need to come harvest that money tree you have hidden in the back yard
    lol, no tree here, just ramen noodles for lunch for the past month if its done in time for ft cobb, it'll go with a big red for sale decal on the scoop, maybe someone up there will have to have it, then i can pay myself back
    Senior Member hotbo's Avatar
    lake Ouachita AR
    tom my phone has taken a dump on me all weekend,tried to answer last night and the ****er wouldn't do anything
    sorry to hear about the issues,but at least you found some decent stuffhow do the bearings look.
    bearings looked new! i'm still putting a fresh set back in, fresh set of rings opened up for alil nitrous in case someone wants to put some on, i'm not , well unless i can't get rid of it this yr., if that happens i'll buy another hitman kit over the winter and stick on it. could let it turn to 6500 if i wanted to, i was pissed off bout the sleeve, but felt alil better after seeing it was for sure a balanced rotating assembly.
    yeah, i herd you pick it up once, sounded like you dropped the phone or something
    Southwest corner AR
    Tom you must be tight with your machine shop to get that in and out so fast! WT
    WT
    WFL Crew!!!
    i called him 5minutes ago to let him know that i was sending the block over and needed it back quik, he put me on hold for a couple minutes, came back and said "i've got the thick sleeve in stock, get it over here" if i get it over there today , i'll have it back by wed-thurs the lastest. i send him all the machine work from the dealership, so he jumps on my stuff when i ask him too. prob spend 500-1000 a month there thru the dealer, not much but nuff to be a "valued customer"
    Senior Member s2k1's Avatar
    Glad you found it before the heads went back on!
    Chris @ Benchmark Performance
    block was dropped off yesterday evening, should be ready wed afternoon hope to be putting it back together so i can go play sunday , race it some
    Derby, Kansas
    You still trying to run this deal at Ft Cobb? If so you sure like getting ready at the last minute.
    if i get the impellor in and the motor lit off friday nite, i'll be beating on it all weekend trying to get both boats ready for cobb but it ain't looking good with all the issues we've had this past week. when it spit the dizzy outta the turbo boat, the turbos got hurt and we're rebuilding them tommorrow nite 251 bucks worth of bushings and crap we may end up just goin to broken bow sunday to race instead of racing at cobb. even if i'm not ready in time i wanna go, at least i could trailer for hass.
    Derby, Kansas
    Damn sounds like you have a cloud above you, busted a distributor and killed the turbos?!?!?
    Good luck getting everything back together.
