Holley Question & Pics...
Results 1 to 10 of 10
    The Right Coast/SE-PA
    Question Holley Question & Pics...
    850 annular list #9380...anyway of knowing (if) these metering blocks are the correct ones for this carb?
    Thanks for any feedback, Ray
    Holley has tech specs online, or you can phone them and a tech guy may be able to help you out. They seem pretty good with the questions I have asked on the phone.
    Bullhead city AZ
    i have the same carb i will go see what mine are
    Complete specs for list #9380
    Model - 4150
    CFM - 850
    Primary Jet - 78
    Secondary Jet - 78
    Primary Power Valve - 6.5
    Secondary Power Valve - 6.5
    Pri/Sec Squirter Size - 31
    Primary Metering Block - 134-163
    Secondary Metering Block - 134-212
    Model - 4150
    CFM - 850
    Primary Jet - 78
    Secondary Jet - 78
    Thanks for that...should those #'s be stamped on the metering blocks because I don't see it ???
    I got this carb second hand...just trying to make sure it's right. I know my secondary acc pump is 50cc the front is 31cc
    Quote Originally Posted by 2savage4you View Post
    Thanks, I sure would like to know what numbers are stamped on top of the metering blocks. Heck let me know where your jetting a PV's are too
    Bullhead city AZ
    Mine match your #'s
    Thumbs up
    Mine match your #'s
    Hmmm so you're saying your primary metering block is
    #8543 and secondary is #9108 ?
    Just for giggles any idea where your jetting is ?
    Thanks again, at least I feel better knowing I have the correct metering blocks and they're located in the right positions
    Bullhead city AZ
    Shit!!!! I dont remember all i know is the numbers matched , tomorrow i will pull the scoop off again and see what is what..
    When i bought the carb it was jetted with 92 primary and 94 secondary that was run on a 460 BBC in a v-drive that hauled azz.....
    I am running 84 squared and it seems to be ok, i might even go back up in jetting once i get time for more testing
    Thumbs up
    Thanks, and if you could, please do check those block numbers and their locations. Also, the 9380 was designed for square jetting, not sure if a fatter secondary is a good idea unless changing out the metering blocks >beats me, and why I'm here asking questions about my carb.
