Nitrous Compatible?
Results 1 to 14 of 15
Nitrous Compatible?
    Senior Member W.O.T's Avatar
    Campo Ca
    Default Nitrous Compatible?
    OK Heres what I got Could I throw Some Nos at it for a little oomph? Ive read about people pushing a hundred shot for a 5mph gain and being pretty harmless. How Much Would it cost? Good Idea? What all would I need To Do?
    I dont race but wouldnt mind a little squeeze and few mph in a little lake/ river pass.
    461BBC
    Merlin Iron Heads
    Hydraulic Roller Cam
    Scat Crank Forged Pistons
    Tunnel Ram 2 750 Demons.
    About 10:1 Compression run half race gas.
    Motor Normally runs about 6k with fresh pump B impeller.
    Motor Has About 3 Hrs Run Time.
    Would A Small Shot Help Without Having To Go Nuts And Change A Lot Of Stuff?
    Quote Originally Posted by W.O.T View Post
    461BBC
    Merlin Iron Heads
    Umm....ugh...umm...I'd call that borderline...
    I mean...your only downfall on your setup is that damn roller cam. If only you had a hydraulic flat tappet you just might be able to....
    Yucaipa Ca
    If your motor was stock you could, up to about 150 shot wet system.
    San Diego, CA
    150 shot no problem. Call me
    Boat 405.
    San Diego, CA
    I hope you are kidding around with the above statement
    Boat 405.
    Campo Ca
    Thanks buddy can you pm me your number? My last phone went swimming.
    LaGrange GA
    It's hard to tell sometimes.
    Of course...hence the smileys
    Newton Ks.
    461BBC
    Merlin Iron Heads
    There's no problem throwing a couple hundred on that, just back off the ignition timing a bit.
    H.L. Mencken
    Campo Ca
    Thanks Guys
    Frank, you officially have the sickness brother.
    BTW you making it out this weekend???
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Campo Ca
    Darrell the weekend of the 5th? Im off let me know. Lol We all have the sickness!
    Green Bay Wi,USA
    The only question is? . the rpms your engine will run. I think that is why the hyd roller came into the subject. If the pump loads well and holds it down to a couple hundy more your good to go.Hyd rollers are big and I am probably telling you what you already know, so be careful.
    Newton Ks.
    Wasn't thinking of that, but true.
    He's already turning 6-grand, I added 400RPM on 100-horse Nitrous shot from 5-5400 RPM, later, added 500 from 5400 to 5900 on a 150 horse shot, same pump setup, slightly different engine breathing setup (ported heads).
    Already making 6-large, add several hundred RPM and may be getting into valve float land with those heavy lifters, and an already notoriously very heavy Chevy valvetrain.
    A lot just depends on the springs and cam profile.
    H.L. Mencken
