Toluene mixing
Results 1 to 14 of 26
Toluene mixing
    Arrow Toluene mixing
    I am using a 30 gallon caddy with 93 octane gas, how much Toluene do i need to add to make 95 octane.
    Are you going to paint or blow the boat apart.
    Quote Originally Posted by Ken N View Post
    You might try hitting up DaytonaTunnel here on the boards. If I remember right he mixes some tolulene in his fuel. Not sure if it adds 2 points octaine or not. Some how it is suposed to help with detonation.
    Coeur d'Alene, Idaho
    Default Formula
    Is this what you are looking for..
    Homemade octane booster formulas.
    Note: The prices for the tolune is a lot more expensive today. I could be wrong but I think tolune and xylene is about $14 per gallon today.
    Formula #1 - Toluene
    R+M/2.........114
    Cost...........$2.50/gal
    Mixtures with 92 Octane Premium
    10%...........94.2 Octane
    20%...........96.4 Octane
    30%...........98.6 Octane
    Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
    Formula #2 - Xylene
    R+M/2.........117
    Cost...........$2.75/gal
    10%...........94.5 Octane
    20%...........97.0 Octane
    30%...........99.5 Octane
    Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
    Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
    R+M/2.........118
    Cost...........$3.50/gal
    10%...........94.6 Octane
    20%...........97.2 Octane
    30%...........99.8 Octane
    Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
    Formula #4 - Methanol or Ethanol
    R+M/2.........101
    Cost...........$0.60 - $1.75/gal
    10%...........94.3 Octane (Methanol)
    10%...........94.7 Octane (Ethanol)
    20%...........Not Recommended
    Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
    Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
    R+M/2.........101
    Cost...........$0.60-$1.50/gal
    30%...........Not Recommended
    Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
    Sample Mixture
    To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses.
    Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
    100 oz of toluene for octane boost
    25 oz of mineral spirits (cleaning agent)
    3 oz of transmission fluid (lubricating agent)
    This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
    Default Information
    Extremely good information there. I printed it out for future reference. The "old school" fuel mixers were a breed all by themselves, and usually standing in the winner's circle.....Nothing like the smell of well prepared race gas......Ray
    LOUD BOATS SAVE LIVES
    Toluene purchased here is $19 per gallon cheaper if purchased in bulk quanities.
    Good info
    #55
    you guys just keep an eye on your accellerator pumps on the carb/s and watch fuel pressure if you're runnin a rubber diaphragm regulator know a guy who swore by that stuff up until a couple summers ago, a few torched pistons changed his mind when the regulator got ate up from the stuff
    Senior Member hotbo's Avatar
    lake Ouachita AR
    it is harsh shit.it does work as with alot of the roundy round guys used it with great success.
    Default Boost
    http://www.batterystuff.com/fuel-treatments/OS2q.html
    This is some interesting stuff..looked into it a few years ago, never used it...raises octane rating in full points not tenths, so they say..Most boost the cans state raises by points (which in reality is tenths of a point) if I read the cans correctly...someone correct me if I'm wrong. The boost with this link says it raises your octane by full points..not tenths of point..big difference.
    Default Octane supreme
    I have used the octane supreme, best octane boost I ever found. I spoke at length with one of the chemical engineers there, it was very informative. You can buy it direct here for alot less. http://www.kemcooil.com/specials.php
    If you need race fuel this stuff is not economical but to get into the middle to upper 90s it is the real deal.
    So Cal
    I would not mix more than 25% tolulene with today's pump gas. A lot of today's pump gas already has MTBE or Ethanol in it ... check the pump stickers wherever you are buying your pump gas.
    In the end, today's 110 race gas is a lot more easier to obtain and cost effective too. (about $5.75-$6.25/gal) and if you blend it 50/50, it makes your corrected cost around $4.50/gal for a 100 octane low lead.
    Is it worth mixing and taking a chance of hurting something? Not IMO. You can do it
    If your running fiberglass tanks your going to have big problems, when they start softening up.
    i'm back!! 1QuickCP's Avatar
    Montana
    Quote Originally Posted by BUSBY View Post
    correct I agree...just run race gas and be done with it.....even a blend with pump works great
    Montana
    lol.....oh yeah bigtime ...
