clevite 77 p bearings on a cast crank?
Results 1 to 9 of 9
    Default clevite 77 p bearings on a cast crank?
    i thought the p bearings were heat treated and for forged cranks? my lil 468 has them in it and the dates are from 1991 on them, but both the mains and rods are p bearings. the cast crank has been heat treated and nitrated, which i found very odd, you don't see that here, most will buy forged before spending alot of money on a cast crank. someone balanced the bottom end and really did a nice job on the crankshaft. just curious , i'm putting p bearings back in it, worked fine for 18yrs
    Derby, Kansas
    In Clevite I believe the "P" is for performance and the "H" series is for heavy duty or race applications. If It matters I've always run the "P" in my piece and it's lived since 92.
    i've never ran anything but forged cranks in bbc's, i honestly just didn't know
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Nothin wrong with a P bearing on stock cranks. Forged or cast.
    Most aftermarket cranks are gonna require H bearings for the chamfer.
    knew that about the hbearings, but i wasn't sure bout the p bearings, thanx yall for clearing it up. i've got everything ordered and on its way, man it'd be nice to go a season without building a motor for something
    Senior Member hotbo's Avatar
    lake Ouachita AR
    tom,i have p-bearings in my mill and have for along time,well the first set were clevite,last set were kings.
    my uncles cast eagle crank has p-bearings in it as well and cleared the radius just fine.
    yeah it would be nice to get many years out of a mill without having to turn any wrenches
    It really doesn't matter what bearings you run in it. I mean after all, it's a Chevy.
    The P bearing is suppose to have more of a taper from vertical to the part line. Last set I measured it wasn't much different than the H bearings. The P has a flash babbit on the surface than some say it can smuge and or ball up under extreme pressure. Some remove it with scotch brite. CL 77 "P" bearing have been used by all of the big three on cast cast at one time or another.
    Member MSCobalt220's Avatar
    Aug 2009
    I've done that with P bearings on blown engines and had no problems . It's the cold scuffing that ruins bearing life. A lot of other factors that outrite ruin bearings .
