Cam timing on TT motor?
Results 1 to 14 of 20
    Texas
    Default Cam timing on TT motor?
    I've always had the best luck with 4* adv. on my cam in my N/A motors (jetboats) but i've herd that you don't need the adv. on a forced induction motor. Is this true? I've got the motor apart right now so i'm just wondering where i should degree the cam in at.
    Thanks, Dallas
    Nice!
    Ada, Michigan
    Playing with cam timing or cams, porting, oversize valves, etc and trying to optimize a setup for some small hp gains is more for something that doesn't have "adjustable power"
    If you did those and verified on a dyno the small hp that (maybe) could have been had it would be insignificant to what one more # of turbo boost would add.
    8 - 10% additional torque per # of boost.
    Texas
    Thanks guys, i have the motor apart (lowering the cr to 8.5:1) with the cam at 0* and timming @20* adv. make this motor a total turd when not in boost? This is really just a lake boat that will be running on 91 pump gas and 99% of the time not be in boost. The 514 i'm running was an honest 700+hp motor with a single dominator and 10.2:1 cr, i'd be happy with 1000hp with the turbos. I was thinking of setting it up to run about 5-15lbs of boost (in dash adjustible deal) do you think that will get the job done? Its intercooled and i also have a water/meth injection setup to ensure no detonation too. Thanks.
    Nice!
    Quote Originally Posted by Filucky View Post
    You can put the cam in 1 degree advanced to allow for timing chain stretch if you want.
    Are you saying you plan to have 20 degrees total ignition timing in it?
    i saw that too man, give that thing some timing! try 28 degrees locked and check plugs from there. if you're intercooling and using water methanol when under boost, 28dergrees of advance is still plenty safe at 15lbs of boost, and at 28 advance, when just on the motor it'll run soooooooo much better
    Texas
    Yes 20* on ignition timing. I think i would have to drill out some holes in the pistons to run 20* cam timing. I really just want to get this motor done and some test and tune time in before winter so i have a good idea of what needs to be changed or upgraded. Thanks guys. Dallas
    Nice!
    I completely understand the difference in cam and ignition timing, I just could not believe you would consider only 20 degrees ignition timing. When I worked at Banks in the late 70's, 28 degrees was the standard recomendation.
    28 degrees total would be a good place to get started. Perhaps I would put a little more in it now days, based on my experience, fuel and amount of boost, among other things.
    One other option might be a boost-retard setup if you run mostly out of boost.
    Texas
    "One other option might be a boost-retard setup if you run mostly out of boost. "
    I think this sounds like a very good idea, i have a timing retard box from my old hi compression motors for easier starting. Is it the same box with the addition of some kind of device that measures the boost?
    Nice!
    sell all the stuff you got and buy a 6btm msd ignition box, its the same thing as a 6al but it has a built in boost retard and a adjustable knob you can mount up frt.. they're about 400 bucks new from summit but as i said, it replaces the msd box.
    my mag is lock out at 35 degrees ,I run 15 pounds of boost on a 461 bbc.my buddy has 42 degrees on his mag but he runs alky.
    Texas
    Quote Originally Posted by tkriley13 View Post
    On 91 pump gas i don't think i would be able to hear the motor over the ping'n noise.
    Nice!
    Texas
    Cool, that sounds like the way to go to me.
    Nice!
    sacramento
    i run @ 32* timing with 1/3 110 sunoco & 2/3 91 octaine , twin turbo ,12 lbs of boost & innercooled ( old banks set-up)
