Proform 1050 carb?
Results 1 to 14 of 18
Proform 1050 carb?
    East Side
    Default Proform 1050 carb?
    I was able to pick up a Proform 1050 carb recently and I want to start with the original jets, PV's, etc. for a tuning baseline. The kid I bought it from changed everything all around for his application and "can't remember" what the stock sizes were. I am having trouble finding any specs online. Does anyone know what jets etc came in this carb stock? It looks like it might have had jet extensions judging from a notched float, but those are missing, and the PV's and jets are way off (he had this on his 350 street motor). Any help here would be appreciated.
    go to mortec.com , scroll down to where it shows carb specs, look up a similar holley with the same size, run that jetting as a base tune up
    East Side
    Mortec doesn't have any listings for a 4150 1050CFM Carb.
    Custom user title Big Inch's Avatar
    simi valley, ca
    Holley has that info on their website. Need the full model number from the carb which is stamped on top of the carb body.
    East Side
    Hmmm, Its a 778-67209 I'll take a look again and see what I can find
    simi valley, ca
    What's the specs on the motor anyways. Most of the 1050s are either set up square at like 92s which probably isn't your case since it has PVs so you probably have progressive linkage and something like 82/88s or something like that for stock. Either way look it up it will give you the stock jetting and pv info and everything else you need once you figure out how to decipher it.
    square jet it with 88's and start from there then
    Contact Pro Form
    A.J. Arizona
    Quote Originally Posted by Some Kind Of Monster View Post
    Pri 86 W/4.5 power valve, Sec 93 W/ no power valve, Idle air 70, High speed 28 Hope this helps. Jay
    East Side
    Quote Originally Posted by blownjet13 View Post
    Helps tons! Do you know if this carb came with jet extensions?
    Thanks!!
    A.J. Arizona
    Thanks!!
    Yes in the rear.
    East Side
    Yes in the rear.
    Thanks Jay!
    [email protected]
    Ohio
    I was just wondering how they get 1050 out of a 4150 throttle body. I see Quick Fuel has them too.
    Tim
    East Side
    I just found out that you actually went over to Lopers to ask for me. I didn't even think to do that ultil I went down there to buy the parts. You're the man and thanks again!
