O2 sensor bung location
Results 1 to 14 of 27
    Default O2 sensor bung location
    Picking up a a/f meter and would like to know where to weld the bung. Any particular location?This is my first time playing with one.
    Put bung in this location.
Name:	o2 bung #1.jpg
    Are your headers water injected?
    better not be and you can't run evacs in frt of the o2 sensor i put my bungs @4-5inches past the collector points.
    Lurker
    NC
    If you are just measuring a cylinder bank the above mentioned is a good location. If you want to measure individual cylinders about 10"-12" from the port is about the best. This gives a good consistant reading without messing with the signal at the carb.
    Nope. Running a 108 lobe on the cam and DRY bassett twisties that have been trimmed 6 inches
    No panevac for me. I have a sweet puke tank that mounts to the transom like a top fueler
    What about the clamp on style? Innovations makes one that can be clamped on th ethe end of the exhaust. This way you dont have to weld a bung
    East Side
    bung. This is my first time playing with one.
    From what I have read the clamp in style, is used mainly
    on a dyno. and its not very accurate, you will want to
    weld a bung into your headers, if you are wanting to tune
    your engine rather than read each cylinder you will have to
    locate it in the collector,just after the tubes merge.
    make sure you purchase the wide band, I have tuned a carb
    engine with a narrow band, but you will find that at the most
    power will show rich on a narrow band.
    the one on post #2 of this thread has good reviews
    http://www.performanceboats.com//showthread.php?t=4192
    Arrow 02 bung sensor location
    Where is the best place to weld in a bung for a 02 sensor on a wet exhast system.
    Quote Originally Posted by Ken N View Post
    before the water enters the exhaust system.
    if they have weep holes it will effect the readings also.
    What exhaust system do you have? pics?
    Quote Originally Posted by Some Kind Of Monster View Post
    That looks like you and overkill
    East Side
    _nIm I gave up on that. I'm not the one talking about bungholes
