floater piston pin clearance?
Results 1 to 8 of 8
    Senior Member repoman's Avatar
    norco
    Default floater piston pin clearance?
    what should the pin to rod clearance be. i just bought a set of eagles and srp pistons and a few of the pins are real tight in the rods.
    .0012-.0015 depending on the application.
    El Cajon, Ca.
    That much float in the rods? Dang.
    I've had good luck with about .0003-.0005 in the rods... unless it's gonna be dry sump or pressure fed pins... but that's a different story.
    The Bostick®
    norco
    probably should have gave a little more info. it's a blown 496 with 12 lbs of boost.
    Quote Originally Posted by repoman View Post
    .0012-.0015
    I wouldn't ever go over .0015, and you can run under .0012 if you want, but not below .0010. IMO .0010 - .0012 is ideal. Steel rod, bronze bushing, standard pin.
    norco
    thanks for the info. I appreciate it.
    Iuka, Mississippi 38852
    steelcomp, if .0012-.0015 is the recommended assembled clearence, what is the operating temperature clearence? i`m guessing the rod and pin expand at the same rate but again, i`m just guessing.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    .0012-.0015
    I set mine to .0009, mahle recommended .0008 to .001. Why so much extra in this case than what they told me? Is it because it's blown? Just curious.
