Old school vs New school
Results 1 to 14 of 22
    Placentia, CA
    Default Old school vs New school
    Turbos for the 621cu BBC build. Pair of Garrett 91's. Huge compared to the little Rayjay 301
    steveo143 AKA DiMarco 21 II
    Ada, Michigan
    Thumbs up
    Those should do the job.
    What A/R is the turbine housing ?
    Placentia, CA
    Hot side 1.16
    Ada, Michigan
    Was there any other A/R choices on the turbine housings ?
    I guess I would have preferred a T6 flange over the V band for a turbo that large.
    On E85 I've been running 1.32 A/R and feel I need to go larger to work with this fuel. The boost is still way above where I want to be.
    I checked it yesterday and it was on the rev limiter at 7700 / 26# boost with the wastegates wide open. I certainly need larger gears than the 37s.
    Placentia, CA
    I would have prefered a T6 flange also but the price was too good to pass up. Found these on Yellowbullet and they were local to me. Hate to buy something like turbos sight unseen and hope that they don't get wounded during shipping. The hot side housings are made by "Precision" and and are supposed to be 16 lbs. lighter. I don't want to rev that high in mine. I plan to start with 48's and go up from there. You should be able to get 48's in your box without cutting the water jacket, don't need the water anyway. What size blowoff's and wastegates are you running?
    sacramento
    hey stevo the turbine housing should be able to be replaced with a v'band to the compressor & t6 to exaust. is the v-band the same size as the rajays to the compressor?
    Quote Originally Posted by steveo143 View Post
    Sure Steve 'rub it in'. With all the bearing, shaft, seal and wheel improvments over the years, those two Garretts will take less effort to 'spool up' than the ONE 301E ! "Way back we would have to "rope start the blowers (turbos) and then crank up the motor" HA HA ! NICE!
    Ada, Michigan
    I've had friends with roots blowers tell me that after they got it restripped it took a 2' long bar to roll it over
    That would be a clue to me.......................
    Compare that to my turbos that are still coasting for 30 seconds after I shut the motor off.
    Placentia, CA
    Quote Originally Posted by turbo wog View Post
    I'm going to fab a transition from exhaust headers to v-band and will actually have more mounting choices. Place to egt and o2 bungs.
    Ada, Michigan
    With E85 even those big diesel turbos are going to go nuts.
    I planned on starting out with lower boost too.
    I just talked to Bullseye power and the tech guy said that with E85 two wastegates per turbo is going to be the only way to get the boost down around 15#.
    I questioned about using larger turbos but still the 1.32 A/R turbine housing is the largest available even with larger compressors.
    Evidently this is a common problem with ethanol and methanol.
    What are you using for headers ?
    Put up a pic of them.
    You're going to want those O2 bungs after the turbos.
    Placentia, CA
    I have a pair of cast alum. Drake/Eickert manifolds with 21/8 primaries that I was going to use but if I get that set in spam I will use those. The polished stainless is very unique. I am having a sheet metal intake fabbed now with a burst panel and 2 blow off valves.
    sacramento
    stevo , those turbos look as though the lag would be extreme. isn't that too big of a turbo? unless of course your running 60lbs of boostjust wondering ,but could be just the picture . i'm thinkin' "fair warning"
    spokane, WA
    Those 91's will have no lag with a 621 inch engine!!
    Quote Originally Posted by TwinTurbo540 View Post
    exactly! and having 1.1ar housings, shit's gonna spool fastttttttt
