Blow-by
Results 1 to 14 of 40
Blow-by
    Colfax, Ca
    Default Blow-by
    468 BBC, 13-1, roller.
    Yesterday developed severe blow-by out of the breathers. Did a compression check, #7 60, the rest 170 to 185. Haven't pulled the heads.
    What might I find????
    ill bet number 7 piston has a hole burned the near the intake valve relief thru the ring pack, i have had a few of bbc chev that that did this when i was trying to mad scientist my own race gas.
    I hope not,but blowby and low comp on one cyl this is my best guess.
    as for the cause the list maybe long,bad or low octane,lean cyl, fuel delivery/supply failure
    please let me know i might have a free spare for ya. good luck
    Morgan Hill
    Half of the ring lands in the pan..........Just in time for fall....
    GT
    GT
    Borrow a boroscope and look inside before you tear it open.
    From Vinnie's movies you sure gave it a workout yesterday!
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    I would leak it first.
    Let me know if you need to borrow a tester.
    But it sounds like something is a fowl with a piston & or cylinder.
    It is supposed to be hard, if it wasn't hard everyone would do it. The "hard" is what makes it great. - Jimmy Dougan
    It's a celebration bitche's - Rick James
    Akita's & Boats: http://s255.photobucket.com/albums/hh149/K-Morg/
    Ok....I'm retarted....so what...
    Quote Originally Posted by Cole Man II View Post
    Tony, Tony, Tony....
    If dragboats were gay, that would make you Harvey Milk...
    Well if you want to make up a bunch of numbers to be right, then yes, that works.
    Senior Member repoman's Avatar
    norco
    I had a similar symptom and it turned out i blew a head gasket from the cylinder to the lifter valley.
    Quote Originally Posted by repoman View Post
    good post repo. i had a older mark 4 block do that did that on number five, put a reher-morrison add a lug kit and o-ringed the block at the same time went to sce copper gaskets.
    morg has a great idea run a leakdown test and see where the air's going should be quick test.
    went down and looked in the shop and i have a new old stock trw L2307A .060 only have one but it's free if you need it.
    Colfax, Ca
    Thanks for the info and offers. I am not sure when I am going to tear it down. But, I will post what I find.
    Sacramento Ca.
    tim if you need a hand im game.. always good to see ya.
    Colfax, Ca
    Didn't do a leak down, but hit #7 with air. Serious air coming out of the exhaust port. Bad valve?, but why would it have major blowby out of the breathers???
    Engine is still in the boat, will be coming out in the next few weeks.
    Gone
    Sparks, Nevada
    Quote Originally Posted by Morg View Post
    No shit. You're learning. Could be just a little piece of carbon on a valve seat. Broken spring, valve lash, etc, etc.
    Leak the whole motor first. Example: Maybe #6 exhaust valve is creaping......while the head is off you can lap the seat. The more you know before you go in there....the better off you are.
    Then take the valve train loose and leak it again. While putting air to #6.....you feel air coming out of #4 plug hole. Look for head gasket sealing problems that way.
    Senior Member Factory1's Avatar
    Did you have the #7 cylinder at TDC on compression stroke when you hit it with the air?
    Colfax, Ca
    Blown head gasket into the lifter valley.
    Gone
    Sparks, Nevada
    Yeah. The bolt chevy left out.
