Who's got?
Results 1 to 10 of 10
Who's got?
    Senior Member cheyenne580's Avatar
    Default Who's got?
    Dart Big M block 9.8 deck 4.500 bore and good steel crank 4.00 stroke?
    Jim S
    Mohave Valley/Quartzsite
    Quote Originally Posted by cheyenne580 View Post
    Jim S
    Check racingjunk.com or ebay. I bought my Dart Big M for a very nice price on ebay!!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Jim S
    who's gotta dart block hookup would've been a better thread starter
    Senior Member Futs's Avatar
    Orange CA, Big River
    I have a merlin 2 block 4.530 bore and a lunati crank detailed by lopez...
    I have a dart big M. Brand new. 9.800 deck Set at 4.600 bore. 55mm roller cam bearings and jesel keyway lifter bores. first two grand takes it.
    Gone
    Sparks, Nevada
    Cstraub has the best deals I have found.
    Senior Member Red Rocket's Avatar
    winchester, ca
    Quote Originally Posted by Wannabe View Post
    What size lifter bores and who did the cam tunnel and the lifter bores?
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    I heard you needed a good crank? Let sme know....
    Default Dart
    I have a 10.200 / 4.500 brand new with steel 4 bolt caps. $2100..... Matching intake for Dominator also $325 new
    Senior Member CNC BLOCKS's Avatar
    Sep 2009
    Jim S
    A Big-M Sportsman block all machined,Decked, Line honed, lifter bores clearanced, bored and plate honed is 2595.00 and shipped free till October 1st after that there will be flat rate charge of 100 dollars on BBC and 75 on SBC any where in the U.S.
    A Big-M billet cap block all machined is 2995.00
    To Blue print bore the cam tunnel over size is 500 dollars and to machine lifter bores to .875 or .904 is 250.00
    All our block machining is done in a HAAS 4-axis CNC machining center and here is a link on blue printing a block I did years ago.
    http://www.chevelles.com/forums/showthread.php?t=93124
    Here is what has to checked on the Big-M blocks
    Some block notes:
    I deck all of them to a finished number depending on gasket & desired piston height
    Block needs to be honed with a plate or bored & honed depending on bore
    Bottoms of bores need to be chamfered
    Most need the lifter bores honed, at the least checked
    Most need line honing
    All pipe threads need to be retapped
    Oil return from fuel pump cavity needs to be done
    Core plug holes need deburiing
    CHECK THAT THE DISTRIBUTOR GEAR DOES NOT CONTACT THE BLOCK BY THE CAM. There is a big cast blob down there you may want to relieve.
    You can machine the gear to clear if you forget but it is nicer to fix the block if necessary
    Check all the timing bolt holes with air, some may go into water. Same with the motor mount bolts.
    Do not use restrictors in the internal oil passages or if you must at the least drill them to about .100
