Turbo or Supercharge?
Results 1 to 14 of 36
    Jul 2009
    Default Turbo or Supercharge?
    I am very new to performance engines but I have a great time learning on this forum.
    It seems like turbos are the new thing....is a twin turbo setup better than supercharging? I have only seen the turbos in smaller v-drive boats...is anyone running turbos in a 26ft + DCB for example? Why don't you see that?
    Thank you
    Placentia, CA
    I built my first twin turbo boat in 1978. Blowers take horsepower to make hp. Turbos are free hp.
    steveo143 AKA DiMarco 21 II
    Only downside is you HAVE to use watercooled housings under a hatch, and they aren't real common, or cheap...
    sacramento
    Quote Originally Posted by dnewps View Post
    Thank you
    if believe that at 8 lbs of boost you gain 75hp out of the turbos over a blower. at 15 lbs of boost you gain 150hp & 23 lbs of boost you gain 225 more horse power over a blower & turbos are 100% guaranteed not to blow a belt thats what i heard . on my ford lightning truck i put a whipple supercharger on it & they said if i went twin turbo it would be a 200 hp gain. i didn't have time for the fabrication. it was work season
    Jul 2009
    If I wanted to build a 900hp twin turbo for a sterndrive 26ft cat....what block and CI would work best for cost and long term reliability....could this be turn key? Are turbos easier on drives than superchargers?
    Ada, Michigan
    Turbos are the best way to go IMO but if it has to be under a cover then the heat issues are overwhelming.
    Water jacketing everything is extremely costly and removes some of the heat that run the turbos. You will be limited on what turbo you could get with a water jacketed turbine housing. I've never seen a water jacketed turbine housing with a T6 flange.
    Guys I know who hooked a big turbo motor to an outdrive broke the drive repeatedly.
    I would look at a big Procharger setup.
    They work great with a remote intercooler.
    Atlantic Beach, FL
    The turbos are very efficient and make tons of power. Roots blowers are easy to install, widely available, do not create plumbing and heat issues.
    The turbos are very efficient and make tons of power. Roots blowers are easy to install, widely available, do not create plumbing and external heat issues.
    Fixed it for you...
    Chico, Ca
    X2
    the big F3 prochargers are pretty easily going into the mid 1000s for hp...all depending on how big of cubes and how much boost. even some are going into the 2000 hp range. check out the steve morris racing engine site http://www.smreperformance.com/
    AP
    spokane, WA
    X2
    AP
    You need to make atleast 750 hp N/A to be running an F3 or it is just not worth it! An F2 will make you 1600 no problem and if you did have the engine for it an F3 will get you 2500+....
    The people at SMRE performance (kim and cj) have been very good to me!! Steve Morris is no longer a part SMRE though.....
    Travis
    Senior Member pwerwagn's Avatar
    Los Lunas, NM
    A few guys here in albuquerque run Turbo motors, one in an HTM and one in a DCB. They have problems due to heat all the time, as well as drive issues.
    When they run, they run good though.
    1985 Fineline Centurion tunnel, 1988 200hp merc, "Still Halfast"
    2001 Carrera 257 Effect X, Twin 2000 Pro Max 300's, "Halfast^2"
    Jul 2009
    can you turbo an engine with 10:1 compression. I understand that the higher the static compression the greater risk of detonation....I just don't know the details or how musch is too much compression. Can someon give me an explanation. Thank you
    Junior Member ImOnaBoat's Avatar
    Aug 2009
    Provo, Utah
    you can run high compression with FI, i know of a place back east that runs little 2 liter engines on 11:1 compression and around 30lbs of boost and make near 1000hp with race gas and water/meth. it will give you very little room for error for detonation unless you are really experienced with tuning and you will most likely have to do this on race gas or water/meth injection or both if your running high boost just for good measure, it will give you alot of gain though not to mention the better response and power you will have off of boost. which is why i like turbos over superchargers you can cruise and idle on a tame motor but really get crazy when it starts to load the turbos.
    as far as heat goes, with turbos you can wrap the manifold in heat wrap and it will make your engine bay temps lower.
    but i would choose a turbo over a super any day from my experiences
    Jul 2009
    lets say we are talking a NA motor with FI and 10:1 compression putting out 700hp on 91 octane and I wanted to go to 900hp SAFELY! on 91 octane. how much boost would be needed....how do you calculate that? I am thinking of something that can cruise mostly out of boost but have the boost for the top end? Is this a good idea or is a lower compression engine better?
