Thanks Chris Straub
Results 1 to 14 of 57
Thanks Chris Straub
    San Diego, CA
    Default Thanks Chris Straub
    Big Thank You to Chris Straub today. Another one of his cam's makes big numbers. Looking forward to October!!
    Lance Patton, Tom Vique 3V Performance, Carl Hinkson CNC blocks. Thanks Guys
    Boat 405.
    Canyon Country, CA
    Really? Really?
    Thats it?
    Santa Clarita
    Quote Originally Posted by Robert Jonsson View Post
    Really? Really?
    Thats it?
    Turns out he's also allergic to posting real information. Big Numbers....Worthless!!!
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Stock heads???
    Southwest corner AR
    SSSSHHHHH! Be very very quiet! great numbers are always good to here!
    And? WT
    WT
    WFL Crew!!!
    Tri-Cities, TN
    Congrats Kjell on a great project, I enjoyed it. Good luck this weekend.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    when you pay for a custom cam, you're payin for the knowledge of the cam builder , and that's not something you just give away on the internet my lil 468 picked up almost 30psi of cranking compression and 600rpms with 1 of chris's cams, he's got my biz from here on out
    ohhhhhh chrissssss, got a blow thru 5.3liter alum headed 9.5 to 1 325sbc i'm putting together and will be needing a hyd roller for it soon, you been doin any blow thru cams for ls motors yet?
    Spiral out MikeF's Avatar
    If I go 82mph at 5200 rpm.......why do you go 85mph at 6100rpm?
    You should be at least 106+mph.
    I do agree that Chris does some nice work designing cams.
    Looking forward to seeing what Kjell's boat does at the race in Oct!
    Quote Originally Posted by MikeF View Post
    cause i have a shit keel under my tunnel, its not loading properly when its over 80 i could hang the loader below keel and maybe grab some more mph, but it'll be dangerous with this flat keel, the boat already shuts down harder than i'd like. i'm also spinnin a bc-cut to 6100, so its not like i have alot of hp(around 550hpish)
    .....so you've got quite a bit of cavitation or not much clean water to the pump.
    Senior Member Camoman's Avatar
    AREA 51
    So are they top secret or do we have to guess
    There's doing it easy,or there's doing it better
    San Diego, CA
    now worries Tom, mike is just busting my balls. He knows what it made.
    15 to 1 big chief motor. sheet metal intake, autoverdi dry sump, jesel this, jesel that 55mm cam blah, blah, blah. Well over 1100 hp.
    I'm stoked. It took some time, but Chris made it all happen.
    Boat 405.
    Tri-Cities, TN
    15 to 1 big chief motor. sheet metal intake, autoverdi dry sump, 55mm cam blah, blah, blah. Well over 1100 hp.
    I called you back, yeah, Pancake flat on the curve...
    Chris Straub
    Straub Technologies
    how many CI???...what class are you gonna run???
