Alu Donovan BBC sleeves R&R
Results 1 to 13 of 13
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    Default Alu Donovan BBC sleeves R&R
    I asked this on YB and got no replies.
    Alu BBC Donovan block, wet. High end engine shop pulled the sleeves to change bore size and they found small cracks between the sleeves.
    Do the cracks need to be welded? Since the cracks are between the wet sleeves and with the chance of them only cracking again, I can't see where they really needed to be welded.
    How hard is it to do a sleeve R&R usually? I am being told there's only 2-3 shops in the country that can do the job properly........
    Or, anyone know of a good used alu block for sale?
    Thanks, Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    i'm back!! 1QuickCP's Avatar
    Montana
    Save your self a huge amount of grief..just ship block to Donovan and let them fix it right...trust me on this one don't let anybody weld it......
    "High end" shop doesn't know what to do here?
    Put the new sleeves back in and run it.
    Changing sleeves is not rocket science.
    El Cajon, Ca.
    Quote Originally Posted by Jim W View Post
    Thanks, Jim
    Pulling the sleeves are easy when you have the right tools... like a way to heat the block and a proper fitting sleeve puller. If your high end shop is telling you they are one of only three in the country that can do it... their full of it.
    As for repairing, I'd say it depends where the cracks are... that would determine whether you'll have a leakage problem or not. if they are just in the upper area where the block is thin anyways... I wouldn't sweat it... if they are down where the o-rings need to seal... then yes it needs to be repaired. Pics would help to get an idea of what you have to work with. My experience has been... unless the thing is totally split in half... it can be repaired. The key is though... not just to go welding away without securing the block structure and preheating and slow cooling it... otherwise you end up with a pretzel.
    Even this was repairable....
    Almost finished...
    The Bostick®
    Montana
    yup...also this sounds a bit strange..are you going to smaller bore size?? Why yank the sleeves if u are going bigger? there solid to u hit the aluminum so why did they not just bore it? and if ur going big enought to worry about sleeve wall thickness u need a different block anyway??
    And as far as sleeve change goes...haha....we have done that in the pits a few times ,not the best but better than not making the next round. sleeve puller, big rosebud,ball hone, rubber mallet...BAM...your driver red lights anyway...lmfao..
    Quote Originally Posted by 1QuickCP View Post
    It's nice to be able to stick the sleeves in a freezer.
    I was wondering the same thing about the bore and removing the sleeves...not sure I get that one.
    Cantard 71hallett's Avatar
    snow bank
    Unless the brand new sleve has a pin hole. Carry on.
    This is a block that is for sale and I was....... interested.
    Apparently years ago when the big bore stuff was first coming on, 15 years ago???? Donovan was talked into boring a few of these blocks to accept a bigger than usual sleeve and 4.6 something piston. Made the block weak and a few started cracking between the bores. Donovan themselves won't repair the block from what I am told. The shop that has the block now says approx $2,000 to fix it then I still need to buy the block from the it's owner.
    Since it's a known problem and apparently Donovan themselves won't touch it, I don't want the block.
    Thanks for the replies!!
    Jim
    GN7
    Montana
    Buy it dirt cheap, install the sleeves u have, fill solid with block filler,hone.....da ta......
    EBAY TIME !!!..........LOL
    LOL...some guys have all the luck.
    I was wondering about that...
    There's no way to repair that. Anything you do will just crack again, so I can see the dilemma. Sounds like a big paperweight unless someone wants to run it dry on the cheap.
    Jim
    I was told that Donovan told him, you asked for it, we did it, now it's junk so throw it on the scrap heap......
    Jim
    GN7
    Ouch!
