Ford 460 Oil pressure
Results 1 to 14 of 37
    Senior Member Amango's Avatar
    Sep 2009
    Default Ford 460 Oil pressure
    OK so i built a Ford 460 30 over on the pistons, 11.92 compression ratio. ported aluminum heads Schneider 306-14R soiled roller cam 665 lift 316 duration lobe separation 112. Bearing clearances .002 rod and mains. Problem low oil pressure only 15 at idle and 30-35 best hot at 4000 RPM. So i realized that there was way to much oil going to the top end pulled rocker covers and pre oiled engine and i had 16 fountains squirting oil over the heads and on to the ground. Turns out you need to run oil restricting push rods with a soiled roller cam so i invested in a set of costume Smith brothers oil restricting push rods. .040 oil restricting hole in one end. Engine all back together and oil pressure hot is now 25 at idle and 50 psi at 4000 RPM on trailer. I would fill more comfortable around 65 70 psi since my intentions are to turn 6000 + RPM with this engine. ? should i go to a 15W50 oil and do you think i would get a 15 to 20 psi increase in oil pressure. Anyone one have this same problem. It has a Melling HV oil pump tech support said that pump should make 40-45 at adle and 65-75 hot oil pressure at power. Thanks
    058 is offline
    You didn't say what oil pan and p/u you are running and the restricted pushrods are a step in the right direction but IMO the .040" restrictor hole is still too much, I'd try .025" as that will still flow enough oil to lube the rockers and cool the springs. The pan issue could be not enough oil [sucking the pan dry] or too high oil level, [airiating the oil] Also could be a misadjusted or defected relief valve. With your rod/main clearances I'd try to run thinner oil or if you run the 20-50 oil preheat the oil or at least warm the engine carefully. BTW, you didn't forget to install the galley plug behind the distributor, did you? Common mistake.
    Sep 2009
    10Qt. Milodon. stock pick up. The oil pressure is 45-50 cold at idle then drops to 25 when hot. Maybe i should go with a .025 restricter there is still a lot of flow to the top end. Thanks
    San Francisco Bay Area
    Cool
    Quote Originally Posted by Amango View Post
    Does your oil filter screw straight to the cylinder block or do you have a remote filter setup?
    LO
    High Flow Dynamics
    Sep 2009
    Straight to the block. I think i need to restrict flow more to the top of the engine I called Smith brothers push rods and they can modify my rods to make them a .020 restrictor. I think i will try that.
    Senior Member brgrcru's Avatar
    Montrose
    Seems to be a lot of complaints about these Milodon pans. I for one think they suck and will replacing mine this winter.
    The pickup is worse then the pan. Try a Baldwin or wix filter too! JMO!
    Quote Originally Posted by pump squirt & BAIL! View Post
    The pick up is so bad, I actually believe the pans have gotten a worse rap than they deserve due to the pickup. WhenI get chance I will post up some pics of everyway I have seen these pick fail. Not to me, I gave them up long ago. But i have seen some of the things these POSs are capable of doing in a boat motor.
    Did I do ok on that one? Just asking?
    Newton Ks.
    From everything I have seen, the big Fords are not known for oiling problems, Oldsmobiles, sure, but Fords and Chevies, not hardly.
    I'm inclined to think your problem source is going to be found much lower down, in the pan/pickup/pump area and any restricting oil to the top of the heads is just band-aiding the core problem.
    H.L. Mencken
    Sep 2009
    I did not mention this problem began when i switched from my hydraulic flat tappet cam to a soiled roller set up. I have built lots of BBF's but with hydraulic flat tappet cams. This engine before i rebuilt it had 45 psi idle and 75 psi on power hot. The ford block has huge oil galley openings where the lifters ride and the solid lifter from Lunati that I'm running have a oil hole of .090 same as a standard push rod hole X by 16 that's a lot of none restricted oil going to the top of the engine. Set up is the same just more compression bigger cam deferent heads ETC the oil pan has worked fine never had a problem with it in the water at all. Thanks for the help i will post the results when i install the modified push rods.
    Senior Member Camoman's Avatar
    AREA 51
    Stock front pickup? or rear pickup?
    There's doing it easy,or there's doing it better
    Quote Originally Posted by Camoman View Post
    And what type oil pump ?
    Sleeper CP
    Big Inch Ford Lover
    Sep 2009
    Front sump! It has a nice trap door to keep the oil around the pick up. Does anyone have a picture of a moroso 10QT and the mildon 10QT oil pan for a ford 460. I don't now witch one i have but it has a nice built in windage try to keep the oil from walking up the back . Melling M84BHVS HV oil pump.
