Olds 455 Cam
Results 1 to 6 of 6
Olds 455 Cam
    Sep 2009
    Green Bay, Wisconsin
    Default Olds 455 Cam
    What is the best Cam to run in mostly stock 455 jet boat?
    Tri-Cities, TN
    Which Olds head?
    How much RPM?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Senior Member hotbo's Avatar
    lake Ouachita AR
    i have a friend that runs the comp hyd.280 cam in his olds mainly stock other than intake and carb.runs great and he loves it.
    good luck,Travis
    i have a comp 280 i love it but im going bigger this year so it will be for sale soon if your interested it has mabye 12 hours on it but like i said it works great in my motor
    .030 forged 10 to 1's, recon rods, arp bolts throughout, ballanced, 4 oil restrictors, hv pump, home made 7gt kickout pan, ported and polished ka heads with 2.072 and 1.685 stainless undercut valves, comp springs, edelbrock performer )wich is also for sale brand new in july ) modello pushrods, and roller cam thrust kit.....with through hull exhaust it pushed my 2100 lb boat for 66 with 3 people and a half load of fuel
    Sep 2009
    Right now i am running - J 411 783 heads with an Edelbrock Torker intake and a holly 650. I am looking to run around 5500 rpms
    Aug 2011
    Thumbs up fyi C HEADS
    Quote Originally Posted by netsak4 View Post
    C heads flow the best of stock heads ; and MONDELLO of CA. CAN SET YOU UP WITH THE CAM TO MATCHYOUR SET UP.
