any engine builders help
Results 1 to 7 of 7
    Senior Member culprit294's Avatar
    sydney
    Default any engine builders help
    i have 2 merlin3 blocks 1 ,4yrs old 2, 15minuts old they chewing out the exh side of the lifter holes big time the intake side r fine anyone had or come across such a problem any suggestons on it. dean. sydney australia. ps they r wearing head to head not side to side.
    El Cajon, Ca.
    Quote Originally Posted by culprit294 View Post
    What type of lifter are you running?
    Had a simmular problem a few years back, severe galling on the lifter and lifter boer. Turned out the material of the lifter and the material of the block didn't get along... bronze bushed the lifter bores and problem was gone.
    The Bostick®
    sydney
    crower severe duty lifters could u move the lifter in boar on yours and was it just exh or int to thanks dean. what block did u have
    El Cajon, Ca.
    It was a merlin 2 or 3... they didn't move around much... but were galled up pretty bad to where they were sticking in the bores and chewed the bores up... I had one do this and a couple of other folks were having the same issue at the time and ended up fixing 4 or 5 blocks all with the same problem with the bronze lifter sleeves. All were using Crower lifters... 3 had the hydraulic rollers and the others were solid roller.
    The Bostick®
    yep
    yep is offline
    dean give argo a call im sure they have the jigs to resleeve your lifter bores if i remember they do blocks for madness
    waterloo
    Are you restricting oil?
    Wags
    sydney
    i am but will drill restricters a little bit bigger dean.
