ok, let's see how far of sim programs are, use you dyno program on this!
Results 1 to 14 of 34
    Default ok, let's see how far of sim programs are, use you dyno program on this!
    here's the basic need to know stuff on my lil mighty mouse project single turbo sbc. parts are bought, motor is goin together and i'm goin to dyno after xmas, hopefully the 2nd wk of january.figured we could play with our sim programs and see wtf its "supposed" to put out:
    gm lm7 5.3 liter 325 cid
    706 alum heads with factory size valves
    gm hyd roller hotcam 218/228duration 525/525lift 114lsa
    76mm inducer garrett turbo with .96 ar and will move 94lbs
    open exhaust
    750cfm blow thru carb
    huge air to water ic with at least 150% efficiency
    gmpp max flow carb intake
    here's the headflow file:
    Stock Head Flow Numbers
    Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
    Intake 200 cc----------63 ---128----179-----210----218----221-----226
    Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
    Combustion Chamber Volume: 61.15cc
    Compression Ratio: 9.5:1
    Intake Port Volume: 200cc
    Exhaust Port Volume: 70cc
    Intake Valve Diameter: 1.89 inches
    Exhaust Valve Diameter: 1.55 inches
    the motor will race on 18-20lbs of boost(on pumpgas) and will live 95% of its life at 15lbs of boost on pumpgas
    i did my numbers at 18lbs and keep coming up with over 1100hp at 6500, lil over 1000ftlbs at 4500. what do yall come up with?
    I'm a total rookie, very much wet behind the ears. Will detonation be an issue with a 9.5:1 motor and a turbo on low octane fuel? How much heat can that intercooler pull out of the system? Sounds like an awesome motor!
    okie, lake Texoma
    Tom, I hate to tell ya this but the eff. of that intercooler isnt going to be anywhere near 150% with an e-bay intercooler, probably wouldnt make that happen with a good intercooler .
    If the turbo/supercharger puts 150 degrees F into the charge when compressing the air, and the intercooler removes 110 of those degrees, then the efficiency is:
    Eff = 110 / 150 = .733, or 73.3% (this formula is straight off the bell site)
    http://www.are.com.au/feat/techt/intercooler.htm
    For maximum efficiency a air to water intercooler is the only way. An air to water intercooler can in fact have a better than 100% efficiency rating.
    let's take billy's set-up for example since i used overkill ics on them also. he's making around 250* of hot boost when maxing out on the compressor map. his hat is cold enuff to cause condensation to form on it which means its well below ambient temp outside, so we'll assign say 60* to that temp, and once that emulsifies the fuel thru the carb , its gonna drop that much more, say another 20*, ok, we'll end up with a intake charge at or around 40*(which is about right, frost forms on the intake runners, not just condensation)
    so we do 180/250 =1.388888 or 139% efficiency regardless, we're well over 100%
    i'm runnin a ic that should support twice my hp goal, ic pressure drop will be lower than .2lbs, and the cores inside it are way more than nuff to say its gonna have a 140% efficiency on my deal if not better. when you're using sim programs, all it wants to know by asking for the efficiency is what the intake will see as intake air temp, then it assigns a given value to what ever efficiency# you plug into it.
    the ebay coolers are doin a far better job than they should , but as i said, i went with 2 big 1's on billy's, and 1 huge 1 on mine. even 1 of billy's ics is outflowing that banks deal you're runnin , so i don't see a reason for your hesistation in runnin 1. true bar and plate cores as well, that banks ic you have isn't, or at least it doesn't look like it to me when i saw it.
    another site i frequent alot:
    http://www.stealth316.com/2-turbotemp.htm
    has some nice calculators on there if you're into turbo motors
    Tar Island, Alberta
    Default Math Check...
    180/250=0.72
    okie, lake Texoma
    Quote Originally Posted by muskwa View Post
    180/250=0.72
    its not like boost from the turbos will be at 250, i read on yb that a guy is seeing 180* at 20lbs with 1 turbo, billy's got 2 so it should be lower than that. regardless, don't cry when i spank that 468 with my 325 leave yo bottle on the shore negative nancy, we'll go motor to motor i can say 150% efficiency if i wanna, i'm cooling with methanol after the ic too there bud,lol.
    okie, lake Texoma
    Oh you can .
    J/K
    I just dont want you expecting more than you get
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Wink Torpedo Tom
    Oh you can .
    J/K
    he always does
    he always does
    from what i'm being told by guys already doin what i'm building, i'm shooting low if i wanna send the turbo to be made into a 88, i can change the pistons and rods, make 1200 don't hate, celebrate
    Oh you can .
    J/K
    we'll line em up come may without nitrous and see how it goes downnnnnnn i'm gonna keep giving you shit till you pull that banks stuff off if ya don't a lil sbc is gonna make more motor hp won't matter what you mph, my lil tt will leave so hard so fast, you won't be catching it,lol.
    my lil custom cam came in today!
    here's a good read for you doubters of these ls motors
    http://www.theturboforums.com/smf/in...topic=132278.0
    try doin that to any stock bbc, ole sbc, or bbf mine isn't exactly stock anymore, i couldn't help myself on somethings but i know i'll be layin down at least 900hp before 6500 on pump gas for less than 3200 total investment in the runnin set-up, let's see yall try it
    okie, lake Texoma
    sounds great to me. May it is, let both fill'em up with 91 from the local conaco as well
