Oil weight?
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 50
Oil weight?
    Senior Member Ronboats's Avatar
    Norcal-Santa Rosa
    Default Oil weight?
    I have a 468 bbc with dual 750s. tunnle ram. vertex mag. pretty mild cam. Supposed to be 10 to 1 comp. What is a good weight /type oil to use?
    I use Amsoil 15-40
    Placentia, CA
    I use Amsoil 15-40
    X2 Good stuff. Mobil 1 good too!
    steveo143 AKA DiMarco 21 II
    Newton Ks.
    Quote Originally Posted by Ronboats View Post
    Oh lord.
    You are now going to get recomendations for everything from the 10w-50 Synthetic I run, to straight 50-weight dyno, or synthetic, laced with Lucas thickener, and GM's EOS additive.
    You may also be told to run a remote filter, and not to, to run a huge oil pan and high volume oil pump, and not to do either.
    Bottom line, run whatever the heck you want, and change every so often.
    If you run a thick, single weight oil, with or without a bunch of additives, you get to idle a long time to insure it is hot and circulating the molasses before romping the throttle.
    A thinner oil, not nearly so much.
    Anything that maintains generally 10psi per 1000 rpm running, is plenty thick, and being fed at plenty of volume.
    I run 23psi hot @ idle, 58psi flat out, for miles. 40+ psi hot at any rpm over about 2,000. 50+psi cold idle.
    Moderately modded hyd. cammed Chevy, stock volume pump, 6 qts oil, K&N 2-quart filter on the block, 10w-50 Castrol Syntech.
    5400RPM off the nitrous.
    H.L. Mencken
    Senior Member Factory1's Avatar
    What type of cam, flat tappet or roller?
    Norcal-Santa Rosa
    Quote Originally Posted by Factory1 View Post
    It's a flat tappet
    Is it Summer Yet?! SoCalKev's Avatar
    Santa Rosa
    Cool
    I run 20/50 Full Synthetic and Have 60+ Cold at idle to 70 at 3000 rpm
    Couple hours later I get about 40 psi at Idle.
    460 Ford
    Sanger Super jet in Progress
    i run 15/40 rot but i have a dominator carb so may not work for you. just pulling your leg.
    Lurker
    NC
    Those questions/comment can start quite a.......ummmmmm.....debate?!?!?!
    Tri-Cities, TN
    I know after the Navy spent our tax money testing oil for the Seal fast attack boats (605 BBC engines ran at 5200 rpm for 24 hours straight) that Mobil 1 15-40 came out on top for HYD ROLLER CAM ENGINES.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Yeah but Chris, lets be totally honest here. The was Navy procured Mobil 1. The stuff runs like $250.00 a qt.
    Lurker
    NC
    Not to mention the $5000.00 plastic funnel!
    But then again, how else can they pay for area 51 and the storage of alien crafts without people finding out about it?
    Southwest corner AR
    Dang that would be 2500.00 + filter per change! Now we know why we are in this shape! J/K, I run 15-50 Syn. NAPA that is Valvoline relabled and cheaper! WT
    WT
    WFL Crew!!!
    Senior Member hotbo's Avatar
    lake Ouachita AR
    mobil 1 15-50syn in all our HP mills.best of luck
