555CID BBC Pump gas 898HP.....
Closed Thread
Page 1 of 26 1 2 3 4 11 ... LastLast
Results 1 to 14 of 361
    Tri-Cities, TN
    Default 555CID BBC Pump gas 898HP.....
    One of my customers, Lewis Racing Engines, just got done with a 555 CID. It is a pump gas 11 to 1 engine single Dominator with a set of Boggs 24 degree Edelbrock Victors and a solid roller "cam picker" special. I'l post the sheet when up but she is 898HP @ 6900 and still 870HP @ 7500. Torque was 742#/ft peak, don't have the rpm as of yet. She will idle at 1000 rpm. Cam is a tad over 800" lift and in the mid 260 @ .050.
    Now for the unreal part. . .this is going in 4 door Biscane on the Big island of HI. 4 speed car. Should make for some real FUN.....
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    San Diego, CA
    oh boy... HI will never be the same.
    Boat 405.
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Chris ,
    Mike is a good guy - He has one of the cleanest shops i have ever been in . Nice equipment with sharp cutters . He put ours motor together and It pulls like a raped ape ...
    [/SIGPIC]
    Was the cam pick with the spinning dart board method, or more hi tech loike the way they draw the lotto numbers with the air chamber. What yr Biscane. Must be an import, they don't don't let old cars hang around on the islands to long if they don't run, before they force them into a scrap pile.
    Tri-Cities, TN
    Widow,
    No and when he says its got air. . .well nevermine.
    Lucky,
    Mike is top notch. When he called on this project about me "picking' the cam for it I said sure. He and Darlene are good people along with the "pack".
    GN7,
    Dart board of course but being an air car I hung the board outside so I could adjust for wind conditions.
    Chris Straub
    Straub Technologies
    Tri-Cities, TN
    Peak torque of 742#/ft was at 5400 rpm. Hmm, dual carbs and this may be "jetable"....
    Chris Straub
    Straub Technologies
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    Chris,
    i am thinking of doing a similar engine but on E-85.
    Care to guess at HP/TQ numbers with 13-1 OR 14-1 your cam pick on E-85???
    At over .800 lift will the valve train survive limited use on the street?
    Thanks, Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    Tri-Cities, TN
    Quote Originally Posted by Jim W View Post
    Chris,
    Thanks, Jim
    Jim would not guess at this time. Anytime you get into this kind of power it may say street car but it is a race car on the street. Therefore maintenance will be more frequent then if it was a 700HP mill.
    Chris Straub
    Straub Technologies
    Yup, you have impressed me.
    Quote Originally Posted by 5325user View Post
    which makes me wonder about these HP numbers from a lot smaller motor, a LOT less heads etc.
    821hp @ 7100 rpm out of a 467.....
    12:1 and some 110 made 821hp and was nothing special.....
    GM Mark IV four bolt block. 4.31 x 4.00
    GM steel crank
    Eagle 6.135" rods, Cosworth pistons, JE rings
    Canfield 310cc heads with very mild portwork, 2.25/1.88
    Ede. Victor TR w/(2) 1050's
    Straub custom roller .717/.663 261/266
    Dan Olson wet sump
    MSD crank trigger and Crane ignition
    Made 821 @7100 679 @5500on Trick 110, 34*
    total. Engine held <5% power deviation over 2000rpm
    Cantard 71hallett's Avatar
    snow bank
    which makes me wonder about these hp numbers from a lot smaller motor, a lot less heads etc.
    Gm mark iv four bolt block. 4.31 x 4.00
    gm steel crank
    eagle 6.135" rods, cosworth pistons, je rings
    canfield 310cc heads with very mild portwork, 2.25/1.88
    ede. Victor tr w/(2) 1050's
    straub custom roller .717/.663 261/266
    dan olson wet sump
    msd crank trigger and crane ignition
    made 821 @7100 679 @5500on trick 110, 34*
    what a lunch box.:d
    snow bank
    Nice pump numbers Chris.
    what a lunch box.:d
    GM steel crank
    Dan Olson wet sump
    Every time I am convinced you aren'r that stupid, you go and prove me wrong.
Closed Thread
