555 CID Dyno Run
Results 1 to 14 of 22
555 CID Dyno Run
    Tri-Cities, TN
    Default 555 CID Dyno Run
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Tri-Cities, TN
    Dyno Sheet:
    Chris Straub
    Straub Technologies
    Tri-Cities, TN
    here is the bar graph on the dyno...
    Chris Straub
    Straub Technologies
    Thats a hot dyno if there ever was one..... nice set up seriously
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    Cool stuff.
    It is supposed to be hard, if it wasn't hard everyone would do it. The "hard" is what makes it great. - Jimmy Dougan
    It's a celebration bitche's - Rick James
    Akita's & Boats: http://s255.photobucket.com/albums/hh149/K-Morg/
    Ok....I'm retarted....so what...
    Quote Originally Posted by Cole Man II View Post
    Tony, Tony, Tony....
    If dragboats were gay, that would make you Harvey Milk...
    Well if you want to make up a bunch of numbers to be right, then yes, that works.
    okie, lake Texoma
    oughta be a runner, good job
    The Right Coast/SE-PA
    Nice...I like those numbers (actually 850) at 6,500 NA and on pump gas
    Senior Member smitt19's Avatar
    carmichael, ca
    Default nice
    what are the rest of the specs comp.? how much cam? heads?
    what he said
    Pretty sure it's the pump gas 555 in the now locked thread. I think most of the specs are there....
    Aug 2009
    O.C. & Lost Lake
    What happened to the oil pressure at the end of the run?
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by Burnt Sticks View Post
    Look at the oil/crankcase temp toward the end of the run. The oil was getting down to 10w by then.
    Tri-Cities, TN
    Quote Originally Posted by smitt19 View Post
    11 to 1
    Cam spec's were posted on other 555 thread. It is around .830 Lift on intake and 264 @ .050 and around .800 lift on exhaust and .280 @ .050 on Exhaust.
    Set of ported Edelbrock Victors from Race Flow Development.
    Chris Straub
    Straub Technologies
    Tri-Cities, TN
    NOt our oil pan.
    Chris Straub
    Straub Technologies
