What heads to use???
Results 1 to 11 of 11
    Senior Member Irish Spring's Avatar
    Jul 2009
    Bakersfield Ca,
    Default What heads to use???
    Hello,
    I have an 1992 454 chevy four bolt tall-deck engine casting # 10114182. The guy I purchased it from said that when he purchased the engine he just purchased the short block. He then put the heads on later. When I pulled the heads off just to go through it he has used two types of heads. Can someone tell me witch head I should run on this engine? I have listed the two types below.
    1) cast # 346236 ( peanut ports) open chamber
    2) cast # 336781 ( open chamber)
    After I find out witch head to use I will be looking for a match head.
    Thanks,
    The end use of the boat and engine would dictate which would be a better heads for your application. Hence more info is required, size and weight of boat, drive, purpose, rpm range, other engine components, all these factors will help determine which head is better for your use.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    MI
    781 is the better of the two. Same head as the 049.
    check with Steelcomp and see if he still has some of the 049s he did awhile back.
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    X2
    Especially the rpm.
    It is supposed to be hard, if it wasn't hard everyone would do it. The "hard" is what makes it great. - Jimmy Dougan
    It's a celebration bitche's - Rick James
    Akita's & Boats: http://s255.photobucket.com/albums/hh149/K-Morg/
    Ok....I'm retarted....so what...
    Quote Originally Posted by Cole Man II View Post
    Tony, Tony, Tony....
    If dragboats were gay, that would make you Harvey Milk...
    Well if you want to make up a bunch of numbers to be right, then yes, that works.
    A tall deck 454?
    Okmulgee Okla.
    Quote Originally Posted by sanger rat View Post
    Not the same, but close
    336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports
    353049.....73-84...oval...OPEN...454, 122cc chamber, 255/119cc ports
    well the block is GM any ways
    IS UNDER FIRE
    Jul 2009
    Bakersfield Ca,
    I can run one 781 and the other 049 on the same engine? This is going in a 56 chevy truck.
    California
    A tall deck 454?
    Good call, the casting number 10114182 does show it being a 454 gen V but not a Tall Deck, nor were any 454 as produced.
    also BTW, I've always been told there may be head gasket sealing problems when using some Mark IV heads on Gen V blocks due to the revised water jackets adjacent to the lifter valley. Apparently this was rectified on Gen VI blocks.
    Looks like somebody just slapped some heads on a short block so they could move it.
    Jul 2009
    Bakersfield Ca,
    Ya, that is what I am thinking. I just would like to get it running.
