Discussion...What has Compression got to do with . .
Results 1 to 14 of 72
    Tri-Cities, TN
    Default Discussion...What has Compression got to do with . .
    camshaft selection? Why is this asked when selecting a camshaft for a performance application?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Comp. dictates selective valve timing. What do I win?
    California
    Because to little duration and too much static compression can create too much Dynamic compression depending on the application, or vise versa, too little static compression and too much duration will let all the compression out and make a pig. i'm sure thats just the tip
    Tri-Cities, TN
    The camshafts "work week" is during 2 cycles. . .the intake cycle and the exhaust cycle. What does it do during the compression cycle?
    Chris Straub
    Straub Technologies
    California
    On the seventh day it rests....................now I know I'm wrong
    California
    Just re-read this, Is this a trick question? If the question is pointed at a given cylinder i'd say its resting, but on and engine with multiple cylinders the camshaft as a whole should always be moving something, no?
    If you did your job right at the bottom while the piston is in a dwell state and part way back up, slowly gaining momentum, it is still in an intake mode (in a given RPM range). Below that range, some of the intake charge get pushed back up the intake track. The further below the range, the more so, there by lowering the effective compression of the motor. If I win, please send my free roller to 288/298 @ .050 Drive, BBCalif.
    Senior Member CK7684's Avatar
    Minnesota
    Is this a quiz or something?
    Tri-Cities, TN
    Bob, Let's not get into Ram effect just yet. Let's keep this simple. I promised Mike F I would go into Ram effect and we have this as another "winter discussion".
    Chris Straub
    Straub Technologies
    San Francisco Bay Area
    Cool
    When it comes to camshaft selection, I spend a lot less time considering compression ratio than I do other far more important factors such as the in/exh port designs and their performance, engine displacement, intended rpm range, other engine combination factors, etc. I don't feel compression is as big a factor as many seem to think, when it comes to planning a camshaft. Power making, YES compression plays a big role, but compression's influence on cam profile is not to me as significant as others seem to take it.
    And that's all I'm saying about that...
    LO
    P.s.: Hi Chris, been slammed, hope all's well.
    High Flow Dynamics
    sorry, didn't mean to get ahead of the game I thought you were asking for some advice and I was just trying to be helpfull
    Nechako
    Thumbs up camshafts 101
    i don't know , but it's sure beats call me and i'll sell you a cam when someone asks a cam tech question . i agree with lakes to a point and then with Josh that too much duration without increasing port flow and compression will kill the cylinder pressure and not increase power or extend the powerband .
    Lurker
    NC
    Some interesting replies for sure!!
    Quote Originally Posted by LakesOnly View Post
    LO
    Thank You. You said that so well.
