any rollmaster or n-motion timing set dealers here??
Results 1 to 5 of 5
    Default any rollmaster or n-motion timing set dealers here??
    i've ran into a prob on my lil 5.3 ls motor build and i need a certain style of cam gear(4x cam signal). i've got the rollmaster and n-motion p#'s , but can't find any dealers
    shot in the dark but here it goes:
    rollmaster p# cs1195
    n-motion p# sd7645
    either set will work as long as its double roller and has the 4x cam gear on it. here's a pic to tell the difference. the 1 on the lh with the big long bump on the gear is 2x stock gear, the 1 on the rh that has the 4 bumps is the 4x stock gear
Name:	2x gear 4x gear.jpg
    yeah, but he's outta stock on em. trying to find someone who might have 1 in stock to verify before i drop coin on it. already spent 300 trying to get the right chain set, now i've got 2 billet sets that won't work for me. the company i bought the last set from listed it as fitting a 07 vette which should have been the right chain set but it wasn't their ad said the pic may not represent the actual part so they're sending me a return label for it, at least i get that 145 back
    guys that have thought about these ls motors for boats, don't be discouraged by the trouble i'm having. i wanted a digital ignition system so some of these troubles are self inflicted and i'm just working my way thru them could've bought a normal ls1 msd ignition system and been done by now, ready to run the motor but the ls1 msd box is analog, didn't wanna go that direction with my build so i'm converting my motor into a ls7 style cam sensor and crank sensor which required me to change the reluctor on the crank(which was a breeze by the way, no special tool needed!), and of course deal with converting to a frt pickup style cam gear with a 4x signal. its all just to get a deadly accurate ignition system after all i'm runnin stock cast pistons can't be having no detonation
    Sep 2009
    flowtech induction is a rollmaster dealer. Contact ed curtis
    i've got it handled thanx tho
