Holley jet size
Results 1 to 14 of 14
Holley jet size
    Senior Member Ronboats's Avatar
    Norcal-Santa Rosa
    Default Holley jet size
    Does anybody know what jets the list#6109 holley 750 cfm carbs come with originally?
    Gone
    Sparks, Nevada
    I wanna say 71 & 80's with power valves...but let me check.
    The web says 75's & 76's. But I have to say that doesn't sound right.
    Norcal-Santa Rosa
    Thanks. I'm gonna pull the bowls on my carbs tomorrow and want to know if the jetting has been messed with. Plugs are pretty black looking.
    El Cajon , Ca
    75 front 76 rear and a 8.5 power valve
    Norcal-Santa Rosa
    Quote Originally Posted by Marcsrollin View Post
    Wow! the jets are nearly the same With a pv? weird.
    Gone
    Sparks, Nevada
    Yeah all specs I come up with say the same thing.
    We always wound up with 71's pri with power valve and 80's in secondary with no power
    valve. Guess that is what I was thinking.
    Some guys did 80's square with blocked power valves.
    Only the front had a power valve stock.
    Norcal-Santa Rosa
    And an 8.5 power valve? is there really that much vacuum with dual carbs? Wow! I would never have guessed that high.
    Gone
    Sparks, Nevada
    Well....I know a saw a lot 6.5 power valves. Don't recall an 8.5 in one....but that's a long long time ago. LOL
    Morgan Hill
    Quote Originally Posted by Ronboats View Post
    Nope...Not even close IMHO.....
    GT
    GT
    Norcal-Santa Rosa
    GT
    Thats what I was thinking too. Maybe thats why the plugs look black? Motor seems to idle good, but it is new to me, so I think I may try a lower number pv and just see what happens. Course I dont even know whats in them now, I'll find out in the morning. Still seems weird that the primarys and secondarys are so close to the same with a power valve installed.... But sure enough, the Holley web site says 75 and 76
    Norcal-Santa Rosa
    I'll bet I end up with a setup like you are discribing by the time I'm done messing around with it-70 or so in the primarys, and maybe 76-78 in the secondarys. This is a fairly mild motor. Just seems more logical to me to have all four holes flow the same at WOT.
    Morgan Hill
    Depends on which metering block is used too, there are many different blocks and the size of the PV ports vary. My guess would be a very small "Power port".
    In a dual toilet app. I would go for a 4.5 or so PV to start with. (closed longer).
    GT
    GT
    Norcal-Santa Rosa
    GT
    Yeah, I guess changing two things at once wouldn't be to smart. I'll mess with the power valves before making any jet changes
    Iuka, Mississippi 38852
    i`m running two 6109`s on a 468 with a lunati roller pn 50231 since 1990. after several plug readings i ended up running 76 jets on all corners with 6.5 power valves. motor turns 5850 @ wot in a TX19, b impeller. i had forgotten what jets it came with but i`m presently looking in the holley book and it says 75 front, 76 rear with 8.5 valves. primary discharge nozzle size is .025 and secondary is .032 .
