Vacumm Pumps on non race motors
Page 1 of 10 1 2 3 4 ... LastLast
Results 1 to 14 of 129
    San Diego, CA
    Default Vacumm Pumps on non race motors
    Is there any value besides the obvious of hp gain at higher rpm to running a vacumm pump on a non race application.
    Here is my scenario
    21' daytona.
    509 11 to 1 compression
    conventional heads
    around 750 - 800 hp on motor
    pump gas
    200 shot of n20.
    spend most of its life at idle to 3500 rpm with occasional kilo passes.
    I'm I going to gain enough to make it worth the $1000. Or are there any benefits besides at full throttle?
    Boat 405.
    Senior Member Ronboats's Avatar
    Norcal-Santa Rosa
    What are "Kilo" passes? And how many "lid" passes in a Kilo pass??
    Senior Member Factory1's Avatar
    It's going to make better power throughout the entire rpm range due to increased ring seal. Second your chances of blowing out gaskets such as oil pan, timing chain cover, valve cover, and intake will be greatly reduced because you are taking the inside of your motor from a pressurized state to that of a vacuum. Oil leaks are greatly reduced as well. If you can afford it, it's worth the investment in my opinion. F1~
    San Diego, CA
    Quote Originally Posted by Ronboats View Post
    inside joke. sorry. basically WOT for a while...
    Boat 405.
    Peoria, AZ
    It can help suck the oil off your cylinder walls and wear out rings faster so you can rebuild it as often as a race boat.
    Hope that helps
    San Diego, CA
    Quote Originally Posted by Factory1 View Post
    It's going to make better power throught the entire rpm range due to increased ring seal. Second your chances of blowing out gaskets such as oil pan, timing chain cover, valve cover, and intake will be greatly reduced because you are taking the inside of your motor from a pressurized state to that of a vacuum. Oil leaks are greatly reduced as well. If you can afford it, it's worth the investment in my opinion. F1~
    Okay cool this is what I was looking for. Thank You.
    Boat 405.
    San Diego, CA
    Quote Originally Posted by The Doctor View Post
    Hope that helps
    fwiw. I was thinking of running 12 to 14 inches vacumm
    Boat 405.
    I've been told that 18" of vacuum is where you will have problems with the motor losing wristpins. Unless you are running a drysump, 4 vane pump, and low tension total seal gapless rings, I doubt you have to worry about it....
    San Diego, CA
    I've been told that 18" of vacuum is where you will have problems with the motor losing wristpins. Unless you are running a drysump, 4 vane pump, and low tension total seal rings, I doubt you have to worry about it....
    I've heard the same. We run 16 to 17 in the big chief dry sump motor. But that motor is a max effort drag race only motor.
    Boat 405.
    Peoria, AZ
    It was a lame attempt at a joke. Not my first failure.
    We all fail from time to time, just gotta dust ourselves off and keep trying!
    It will also stop the blowbye at high rpm from pushing that nice oily mist out of your breathers and dirtying up your boat.
    San Diego, CA
    lol.. oh I like projects though
    Boat 405.
    Peoria, AZ
    Isn't that what evac tubes into the headers are for?
    I galled a set of wrist pins in one season w/ 14in of vacuum. We opened the pin tolerances up a couple of ten thousandths and went to a DLC coated pin and everything has been great since.
