plug readings
Results 1 to 2 of 2
plug readings
    Default plug readings
    On my blower motor the rear 4 cylinders are fatter than the front 4 according to the plugs . I am jetted equally on both carbs and the wide band says my A/R is good. So is it worth screwin with each carb individually, maybe leaning the rear and fattening the front or just leave it be?
    Are these plug readings on a dyno or are they from running on the water?
