comp cams?????
Results 1 to 14 of 21
comp cams?????
    Senior Member CHEVY JET's Avatar
    St. Charles, IL
    Default comp cams?????
    I got ahold of comp cams and asked them what cam they recamend for my jet boat. I am looking for a hydrolic roller. The one that they told me to use is #CL456-8, or grind #XM296HR. I am just wondering if any of you have used this cam, and know if it is a good one. (FYI. It is going in to a .030 over 454 with ovalport heads, cast crank, stock rods, and hat .250 domed srp pistions, and a 850 holly carb. The pump is race ready with a ss a/b impeller, dps inducer, loader, and stuffer. The pump has just been gone through and is fresh.) Any and all coments are apreciated.
    Kingman/Golden Vly, Az
    U might get ahold of cstraub here on the boards...he grinds cams & has done so for quite a few peeps...he might have a better cam & perhaps cheaper also ...just my .02 cents
    FastRat
    Redding, CA
    If it is this one:
    http://www.summitracing.com/parts/CCA-11-456-8/
    That is the exact Cam I have in my Miller 454.
    I like it, I think you may have slightly more compression than me, My ratio is 9.4:1
    I have Brodix 280cc Rect. port, with a TR and 2 660's.
    My pump was having issues, so I can't tell you how exactly how it ran very long over 5K, but it showed signs of being able to pull hard well past that with a stainless A impeller.
    Idles crisp at 1100 RPM, I had 36* total advance, w/ around 20* initial.
    I am no racer, or Dyno expert, but I like how it runs.
    You will need much shorter push rods, so don't order any until you have EVERYTHING else mocked up!!
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Senior Member hotbo's Avatar
    lake Ouachita AR
    i have put that cam in 496 build and it works really well.it also was in a 468 mild build and worked great also.best of luck.
    St. Charles, IL
    Thanks guys, I wanted to get an opinion from someone who used it befor I spent the money. As always, this site Rocks!!!
    Quote Originally Posted by CHEVY JET View Post
    here's, use this:
    http://www.compcams.com/Camquest/
    takes the guess work outta it when buyin a comp cam
    Member lethal injection's Avatar
    Jul 2012
    Jerseyville Il
    Default water reversion??
    here's, use this:
    CamQuest ? Select The Perfect Camshaft & Valve Train Components
    im wanting to run the same cam with thru hull Rewarder headers... how does this work with water reversion? also. with the thru hull headers will it burn through the rubber ex hoses with a t valve installed?
    Tri-Cities, TN
    this is great example. One engine is a .030 454 and the other is a stroker 496CID but they both get the same Comp camshaft recomendation.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    You mean you haven't been using camquest Chris?
    QE 439 Twin Turbo
    Tri-Cities, TN
    Ron,
    I guess I am going to have too. Hell if 1 cam fits all it will make my life easier and I can replace this dart board!!!
    Chris Straub
    Straub Technologies
    May 2010
    Discovery Bay, CA
    Here is my build with that cam. I am very happy with it.
    454 4 bolt Hi Perf block bored .060 over (4.31)
    Hi Perf 990 rectangular port heads pocket ported and polished chambers 118 volume
    stock rods and crank with ARP bolts (balanced and blue printed)
    Keith Black Hyper pistons part#257 25.5cc domes (10.5 cr)
    Comp Cams Xtreme Marine xm296hr grind hydraulic roller cam (566 lift 296/302 duration) 112 lobe seperation
    Comp Cam roller lifters
    Comp Cam one piece push rods
    Comp Cams Ultra Pro roller rockers
    Comp Cams Springs and retainers
    Cloyes Double roller timing chain
    Cloyes Timing cover with cam button
    Melling high volume high pressure oil pump
    14 quart Dooley oil pan
    Edelbrock Victor jr 454r manifold
    850 Double pumper holley
    Break Out AnotherThousand
    Jul 2012
    Jerseyville Il
    Quote Originally Posted by orange bahner View Post
    What kind of headers are you running? have any videos so i can hear the cam? that would be great! thanks!
    May 2010
    Discovery Bay, CA
    Quote Originally Posted by lethal injection View Post
    I don't know how to upload a video
    HERE YA GO try this Short video but you can hear it idle a little
    Jul 2012
    Jerseyville Il
    Sounds amazing! Thats exactly what I needed to hear. Cant find anyone running that cam!
    hows the water reversion factor? typical wet injected headers with a t valve ok? Bad ass boat btw!
