Short travel hyd rollers?
    Default Short travel hyd rollers?
    Live long enough and you get to see the same stuff just keep coming around. Awhile back 71Hallett was asking about the best hyd lifters (flat) and I PMed him with a couple of things we used to do back in the sixties, and were considered slightly "illegal". We use to make eactly this same things (except flat)so we couold run solid lifter cams at Lions with a 4 gear and a stock bell housing at the wed. night "hyd" classes. All we were really doing was puttin the solid lifter "lash" in the lifter, which usually worked out to about .012 travel in the lifter. And hey, that's exactly how much these have. There really isn't much new under the sun.
    http://www.compcams.com/Technical/Ca...2010/PDF/9.pdf
    I think Morel has had limited travel HR's for years.
    Tri-Cities, TN
    Yep, no more then .030" travel. These are set at "0" preload and you can run some decent seat and open pressure on them.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Yeah, we just did it a little different. We let, or more correctly, wanted the lifter to collapse, and quickly. Because all we really did was put the lash in the lifter. The idea here is, I guess, if it collapses, thats ok, because it does loose that much lift.
