oil filter line routing
Results 1 to 14 of 16
    Senior Member nasty toys racing's Avatar
    Default oil filter line routing
    ok call me stupid but i was trying to figure out on a remot filter ,were does the line come in at and were does it exit at on an oil filter,on a fuel filter the fuel comes in and goes down in the filter via the center,were the element screws to the housing and comes out were the little holes are and to your fuel pump,am i correct or not ,so i was in ahhh about the proper way to rout the lines on a oil filter,does it go in on the out side were the little holes are and out from the center ,or is it the opposite,does any body have a diagrame on this thanks
    clean oil out from the center of the filter
    #55
    Leaving the block:
    Outside fitting is OUT to the remote filter (goes into the filter on the out side)
    exits filter from the center. after the filter/cooler, the oil returns to the block to the inside fitting.
    from the block:
    Outside is out
    Inside is IN
    Quote Originally Posted by 5325user View Post
    Leaving the block:
    from the block:
    Outside is out
    Inside is IN
    Careful, you can't make that statement without seeing his adapter(which is a Rex). The "inside" fitting goes from the block to the remote filter, since the "outside" fitting in his case is in the center, the normal return from the filter.
    unique adapter to say the least.
    To make it correct all the way around. Plumb the adapter as needed so:
    oil needs to go IN to the small holes on the outside edge of the oil filter, and then the oil goes OUT of the large center hole of the filter.
    Nov 2009
    so does that mean the NAPA ones filter can take in more crap and last longer?
    The Rex billet oil bypass, upper left #456411 is not that different than many other bolt on bypasses (I have a Bob Teague piece lying on my bench which is almost identical). They are engineered to give a fairly direct path for the oil exiting the block. True, it could be bolted on either direction, but it makes sense to line the passage up to the inside I think. The second image shows the Rex HP 6 remote filter bracket that he has on his boat.
    I guess my response was too simple
    has anybody used or seen the 456-411 gen 6 adapter?
    do you remove the screw on adapter from the block when using it?
    #55
    Yes, I looked at it. This is the Hardin/Canton one that we normally use.
Name:	block adapter.jpg
    Needless to say, I have not seen/used one of them, but the small opening makes it appear that it does.. The one I just posted is a Gen5/6 and it doe need the middle threaded piece removed from the block.
    That one could mount either direction as well, and would make more sense to put the "out" from the block inline with the fitting,, which would also make it the "inner"
    Yes,, it does need to be removed Paul
    Perfect Barry, thats what I need. by removing that adapter it will open up the flow some.
    #55
    There are 2 holes in that adapter. one in the middle, and one on the outside. When the "O" rings are in place, and its bolted up, the oil coming out of the outer hole in the block goes through the outer hole in the adapter, and the oil coming back to the block goes through the center hole in the adapter into the center hole in the block.
    A hole in the middle of a circle is always going to be in the middle,(inner) no matter how that circle is placed. So how would the outside hole be the "inner"?
