ebay turbos
Results 1 to 8 of 8
ebay turbos
    Senior Member bigblock68's Avatar
    Default ebay turbos
    anyone used these cheap turbos on ebay
    junkkkkkkkkk
    what are you wantin to put 1 on ?
    fixin a twin turbo setup on my jet boat its a 454
    okie, lake Texoma
    Quote Originally Posted by bigblock68 View Post
    go with a couple s475's from paradise racing, about $600 each and worth every pennie.
    capable of around 2000hp
    just want make around 800 hp my motor should be around 500hp now
    okie, lake Texoma
    then I'd watch the spam section for a Banks or PFM setup, should be able to pick the whole setup up for less than 2k and it'll make your goals easily.
    not a fan on that carb deal they run i have done bought my headers to was wanting to do a blow though system
    i have a 454 440 marine mag bottom end which is forged going with a roller cam i have a set of 325 cc aluminum heads air gap intake how much hp can the take and live its a 4 bolt main and its a marine block it seems to be a thicker casting than the car block
