Mechanical fuel injection and tunnel rams
Results 1 to 11 of 11
    Default Mechanical fuel injection and tunnel rams
    What has to be done to do this?
    Gone
    Sparks, Nevada
    The most important thing is the correct barrell valve spool for naturally aspirated injection and not blown injection.
    Describe what you have....what you are trying to do.
    Was noddling an injected deal on my wagon but would like to keep it under the hood.
    Gone
    Sparks, Nevada
    The typical Birdcatcher hat on a Victor tunnel ram deal or what?
    Something like that, or one a dual quad intake of some sort, would I have to inject at the ports? or can it still be done under the hat?
    Is there a perfect comp ratio for injected alky?
    Gone
    Sparks, Nevada
    N/A as much compression as you can get.
    Typically the guys use a Victor cause Enderle makes a top for it. You do inject at the ports. You need a hat (Bird or bug), typical barrell valve, a special spool for that barrell, line kit, nozzles bodys, typically nozzle sizes in the 30's. 80a pump.
    First you start off with no high speed....2 lb light check spring in the bypass off the barrell.
    That's the standard deal.
    On a converter car....held on the line....you may want to replumb the system and create a "secondary" pop off to keep the car from loading up when staged.
    But start with basic system.
    You have to be willing to fiddle with it. And don't think that because you "now have a plenum" over a set of upright injectors.....that you are gonna gain a bunch cause it isn't there. The theory is there but the results were not. My experience with these deals....they are finicky in low throttle open situations where a set of uprights run just as good and not as picky. Your mileage may vary.
    Thank you for the info.
    Senior Member Cat Sass's Avatar
    Shingle Springs, CA
    Heres mine, it ran pretty good, but didnt make any more power than gas and carbs on the same motor. It was 14:1 or so.
    Nobody
    Big River, Ca
    Quote Originally Posted by Alkywagon View Post
    If you want to keep it under the hood and run Alky, might want to use Ron's it's super simple and drivable, friend of mine drove his Nova on the street was a fun deal!..
    Gone
    Sparks, Nevada
    Yes...have also heard good about those. Flying Toilet I think he calls them.
    Nobody
    Big River, Ca
    Yep that's it the Flying Toilet, just took the carb off and used the same manifold and it was night and day!..
