Methanol spray on top of a blower
Page 1 of 15 1 2 3 4 11 ... LastLast
Results 1 to 14 of 198
    Default Methanol spray on top of a blower
    Im thinking about spraying methanol on top of my blower. WHats the pros and cons?
    BBC 454 mag motor,weiand 177 blower,single holley 800dp
    Just looking for a lil more on the top end.
    G H E T T O F O E L I F E
    My budget is very low due to life changing events plus I had "Baby Spitter" this year so I spend all my time with him
    Michael , found some interesting reading for ya check it out ! Tom
    http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
    Member candyred347's Avatar
    Farmington
    Ran methanol this season on a 496 mooneyham 12lb of boost. methanol came on at 9lb. I was able to gain 400rpm. A far as a con dont know yet havent torn the motor down yet. But hope to get to it soon.
    pick up a cheap nitrous plate off ebay in good shape:
    http://cgi.ebay.com/ebaymotors/NOS-n...Q5fAccessories
    cheap holley(knock off) black fuel pump for pressure:
    http://cgi.ebay.com/ebaymotors/ProCo...item2ea980499e
    cheap methanol solenoid to control the plate:
    http://cgi.ebay.com/ebaymotors/Devil...item20a9f12af7
    turn it on with a msd rpm switch, have a methanol kit that's jetable for less than 200bucks
    the biggest pro is you can feed the motor alil more timing and boost on pumpgas
    okie, lake Texoma
    AIS
    AIS is offline
    Dec 2009
    Couple of things worth mentioning. Using a nitrous plate is going to give you no atomization. With out the nitrous your just going to piss fluid out of all the holes and its going to spray a lot!
    The pump you've listed only makes 14 psi and isn't made for methanol. Our pump comes preset at 200 psi, bypasses internally for a smooth even flow and can be ran with 100% methanol.
    The solenoid you listed is fine. We choose to use a one way check valve as they work nearly flawless and no wires to worry about.
    You left out all the fittings you will need, hoses, wiring, electrical fittings, Not everyone has an MSD system to trigger the system so they will need a boost switch or throttle position switch to trigger the system. Not to mention the performance of the system isn't going to match that of a high pressure system like ours and the type of nozzles we use are far superior to using a nitrous plate.
    When you take a look at one of our base kits which comes with no tank it's a pretty rock'n deal! Comes with absolutely everything you need. All the fittings you need, boost switch, 20 ft of 12 awg wire, LED status light, heavy duty inline fuse to protect the pump, heavy duty nylong tubing, one-way check valve, all the eltrical fittings and miscellanous hardware, intructions, technical support and LIFETIME WARRANTY for $240.00 bucks.
    Not to shabby considering our competitors sell the same kit for just over $300.00.
    Rodney
    AIS
    AIS is offline
    Dec 2009
    Thanks for the support. You rock!
    Rodney
    okie, lake Texoma
    Quote Originally Posted by AIS View Post
    Rodney
    You bet, I like the little tanks you guys make for in the trunk that mounts the pump & everything right on the tank, kind of makes it self contained & simple. It'd be easy to hide in one of our boats.
    AIS
    AIS is offline
    Dec 2009
    Wait till you see our new competition tank we have coming out in 3 weeks. Pretty fricken cool design with lots of great new features added to it. Pump and tank all one unit again.
    Rodney
    All interesting, however I've run a methanol Nos system on the 565 since 1993. Once the spray bars were set in the intake plenum I had an extra plate system so we installed it on the engine with just the fuel side hooked-up to a fuel solenoid. I installed a 150 hp fuel jet in it and at 6 psi of fuel psi it helps the engine gain 200-300 rpm on a 100-110* day.
    I doubt that atomization will be a problem whether or not he injects the methanol on the top of bottom of the blower or below. The methanol will vaporize and cool the intake air regardless of where it's injected and regardless of the psi it's injected at so long as he doesn't try to flood the system.
    Just my .02 from someone who's done it since 1993.
    Edit: Mike is thinking about putting the alky in the top of the blower. I'd do it under the blower in the air stream. The hot blower will just waste a bunch of the evaportive affect of the alky.
    S CP
    Silverdale, Washington
    Rodney
    Welcome Rodney. Glad you came on over. Welcome to PerformanceBoats.com.....john
    X2. I've been seriously considering one of Rodneys setups.
    LaGrange GA
    It's almost all pros. The only cons to a good alcy injection system is the initial cost. What's really cool is with a good setup you can run high boost and pump gas.
    Razors kit is installed on a a few daily driven V6 Buicks in the 9's (pump gas and drag radials) http://www.alkycontrol.com/ It puts up with Methanol, has a progressive controller, low alcy warning, etc...
    If you want to piece together your own system this is a pretty good way to do it.. http://members.cox.net/stevemonroe/AlcoholInjMod.html
    Senior Member cave's Avatar
    Mesa, AZ
    Hell Yea!
    Takin it home
