Valve lash
Results 1 to 2 of 2
Valve lash
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    Default Valve lash
    I was just thinking how the cam builders decide out how much or little the valve lash should be
    Quote Originally Posted by APOLLO View Post
    Mostly has to do with the ramp design on the cam. The lifter base diameter. Also when you want it to start opening and closing the valves.
