Intake
Results 1 to 7 of 7
Intake
    Colfax, Ca
    Default Intake
    I an curious about the plug in the bottom of this Weiand top plate!!!
    Kingman/Golden Vly, Az
    i have no clue...have never seen a hole there, unless its for some kind of vac gage hook-up...i say, plug it & forget it ...just my .02 cents
    FastRat
    Iuka, Mississippi 38852
    PCV valve?
    One big ass nitrous nozzle.
    Obviously something someone put there. Nothing to worry about...leave it plugged.
    Oh, and use red loctite on those bolts holding that top to the base. It wouldn't be the first time one of those vibrated loose and became shrapnel inside a nice shiny cylinder.
    California
    I think Weiand put it there, then someone made it two sizes larger(oops). I've seen a lot of older t-ram with a plug in that location, typically only 1/4npt though.
    They probably quit putting them there when they realized pcv valves sucked for high performance apps
    .....pun not originally intended
    It's to drain the fuel if you flood it. No, really.
    cfm
    cfm is offline
    Mounted a mailbox (that looked like a scoop) to it.
