Question Aeromotive A100 FP
Results 1 to 14 of 32
    Rollin With Fink fasterthanu's Avatar
    Norcal
    Default Question Aeromotive A100 FP
    OOPS A1000 Fuel pump not A100.....
    Good pumps, ok pumps, bad pumps?
    Application: EFI on a street car, not a daily driver but when time permits it goes out for a few hours here and there..
    Thanks in advance,
    Denis
    i was gonna use 1 on my boat build but i hear you have to buy the aeromotive voltage controller to make them live, they don't like continuous duty read to many threads on yb bout em goin down even with a bypass regulator.might check into it, but that's why i backed away from em.wanted my pump to match my regulator too
    Kingman/Golden Vly, Az
    Hi Denis...
    how's it goin'?...from my understanding, its a good pump, but, thats alot of pump!...is it a BBC street racer?...u might be better off with a Holley black!...i think ur gonna have to use a reg with anyway u go
    FastRat
    Norcal
    Hi Denis...
    FastRat
    It's going..........
    510ci BBC- Kinsler Stack EFI. Lots of work done to the motor. I need 45psi. Thanks
    Norcal
    Yea I seen the spendy controller. Hmmmm I will have to look hard at other options.....
    Thanks for the info.
    Quote Originally Posted by fasterthanu View Post
    the aeromotive belt drive would work perfect but its alil overkill for what you're doin. the new aeromotive pumps that are "pro series" are supposed to handle the constant duty better than the older versions. i'm gonna buy the obx version that's 200bucks from ebay and try it, obx also makes a knock off copy of the aeromotive belt drive pump, but its only 149 bucks compared to the 499 aeromotive.if i had a way of driving the belt drive obx pump i'd go for it and never worry bout supply again. the belt driven pumps will make nuff pressure during cranking to fire it up too.my uncle's aeromotive belt drive pump was making around 55psi just cranking the damn motor!
    I have the same pump but have not run it yet, my research lead me to this pump. From what I understand, if you are returning back to the tank
    and you have at least 10 gallons of fuel you should be fine.
    #55
    you've ran 1? cause i'd sure like to as well but i've been told time after time they won't work for what we do.
    El Monte
    I have run quite a few of them. However we use the marine one that has the hard anodized body and the marine regulator with the return. Never had a problem yet. A few have been running for 3 or 4 years. The two on my boat have about 80 hours on them and still running strong.
    B & D Marine Performance
    El Monte, Ca.
    No I have not ran it yet. the tech dept at Aeromotive is great.
    they are the ones who suggested I install mine inside the tank.
    #55
    sorry guys, i was thinking about a a2000 pump all along , that's the pump i was mentioning that doesn't like continuous duty and requires the controller, the a1000 is a standalone pump.
    outlaw, did aeromotive say the a1000 would keep up with your blow thru deal or is this on something else? i figured your blow thru set-up would make alot more hp than what that a1000 would hole up too. if the a1000 will carry your big bbc blow thru deal fine, it'd handle my lil blow thru mota you'd think quickfuel told me i need at least 220gph at 35psi to keep ontop of the carb's fuel demand on my deal.
    The Great Humongous P-Money's Avatar
    South Central WI
    Been running an A1000 on my blown 496 for 5 years now, not a single problem (unlike the piece of $hit Barry Grant on my v-drive).
    Norcal
    See how you are!!! Hey no big I wrote A100!! Stuff happens....
    Norcal
    BD and P money, thats good news. I thought they was a good continuos duty pump, I just needed more real time data b 4 I dropped the coin...
    Thanks, Denis
