A/F ratio?
Results 1 to 14 of 24
A/F ratio?
    Senior Member Cat Sass's Avatar
    Shingle Springs, CA
    Default A/F ratio?
    It looks like I am almost the last guy to get an oxygen sensor on my blower motor. What do you guys that already have them shoot for on the A/F ratio. This is a 509 with 8-9 lbs intercooled on pump gas.
    Lost Wages, NV
    In a car, 11.5-11.8. Might be able to go a touch leaner due to you're running an open cooling system and not seeing the temps you would see in a car, but I wouldn't go over 12:1.
    Keith-
    Shingle Springs, CA
    thanks kieth, do you think it would be safe to run a little leaner at cruise rpm? I know the car EFI systems are set up to run as lean as 15-16:1 at light load cruising conditions, and 14.7 under normal conditions. I'm not sure if a boat ever sees a "light load" condition. I have noticed that while cruising at 65 MPH around 3600 rpm, my vacum guage reads 0. Seems like this would be about the same as a N/A motor at wide open throttle.??
    any thoughts guys?
    Lost Wages, NV
    The car scenarios are basically out the window with the kinds of RPM's a boat motor sees to "cruise" across the lake. Given that you're at right near atmospheric while "cruising", I'd shoot for around 13:1, maybe a little richer. Most cars will cruise at 14.7:1 (stoich), but I wouldn't do that in a boat due to the load and RPM.
    BUT, I've never tuned a 4-stroke, supercharged motor in a boat, so I can't give you any info based on past experience...just what I'd probably start at. YMMV.
    Default Air/fuel Ratio
    11.5-11.8 should be good, however it really can vary depending on your monitoring system equipt.
    Quote Originally Posted by Cat Sass View Post
    any thoughts guys?
    Cantard 71hallett's Avatar
    snow bank
    A/F means alot but I would tune with an egt. What we use anyways and lots safer since it would be very hard to say how much load you are really under. P.S. put it on #7
    Paul
    Shingle Springs, CA
    Default air fuel results
    well the first round of testing showed:
    14.7 at idle in neutral
    16 at idle in gear
    10.9 at cruise
    10.4 at wot
    Got some jet changes to try, You can really see when the powervalves open on the meter. Neat-o.
    Lost Wages, NV
    Decent amount of power and economy still on the table.
    El Monte
    Here's what we do.
    Idle 13.5 to 13.8
    Accelerate 12.2 - 12.5
    Cruise no load no boost 13.0 - 13.3
    Cruise with small amount of boost and load 12.5 - 12.7
    WOT 7 - 8 lbs boost 11.8 - 12.0
    These are good general numbers. ALL these numbers will be adjusted depending on what the engine likes. We still look at plugs also.
    B & D Marine Performance
    El Monte, Ca.
    Lurker
    NC
    Paul
    Why would you rather tune with an EGT?
    Member JAY4SPEED's Avatar
    Quote Originally Posted by BDMarine View Post
    Here's what we do.
    Idle 13.5 to 13.8
    Great info, thanks!
    What are your AFR figures with an unboosted engine at load and WOT?
    Jay
    "You just can't fix stupid!"
    El Monte
    Quote Originally Posted by JAY4SPEED View Post
    Great info, thanks!
    Jay
    Normally aspirated engines are a lot more finicky in their tuning. There are so many things that determine what they like. Cast iron or aluminum heads, compression, lobe seperation, etc. Lets say it's a 540 BBC with alum heads and 9.75:1 compression with 91 octane. I would start at 12.7 - 12.8 and adjust from there.
    El Monte, Ca.
    snow bank
    Sorry, wanted to see if anyone else would reply. We use an a/f but it will tell you nothing about timming or the quality of the fuel you just bought. Egt will. You could be rattling away and your a/f is still good.
    Lurker
    NC
    True, but you could be "rattling away" and still not see it with the egt data either.
    Can't remember the last time we used them. Now that doesn't mean they are totaly useless, but I think they are just not as useful as we once assumed.
    Kinda like jetting with BSFC, too many variables effecting the reading to rely on them for tuning.
