049 heads
Results 1 to 8 of 8
049 heads
    Senior Member slotracer's Avatar
    Default 049 heads
    what is the difference in open and closed chamber heads? someone told me, he had a set of 049 open and a set of 049 closed chambers heads, yet on mortec all i see is open. are there 2 different types?
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    Gone
    Sparks, Nevada
    About 10cc"s.
    T&Y
    T&Y is offline
    Sep 2009
    Quote Originally Posted by slotracer View Post
    The physical difference is the area around the valves. There is a set of closed chamber heads in the foresale section right now that shows the head being flat pretty much all around the valves. If that where an open chamber, or partially open chamber you would see more of a circle portion around the heads that has been machined/recessed making a bigger opening when it's mounted ontop of the cylinder.
    I had to physically look at a set of closed vs open to understand the difference.
    As far as is there an 049 in both versions, I have no clue.
    Nov 2008
    Orangevale CA
    The openchamber head's flow better, ( air can get around the valve better ) ,,as far as the #'s ( 049 , I think those are only open chamber )
    ..........................Eric
    049's are all open chamber. They are 113 cc's. They are smaller then a lot of open chamber heads.
    Colorado Springs
    049s are 119 to 123 ccs. 049s are all open chamber and most of the later heads are 122 to 123 cc.
    Quote Originally Posted by jungledave View Post
    My book must be wrong.
    MI
    Your book is wrong. The set I had CC'ed at 118cc.
