Block choice
Results 1 to 14 of 42
Block choice
    Senior Member River Dad's Avatar
    Riverside, CA
    Default Block choice
    What are your choices for a block? The project will be for a 19' jet boat primarily used for the river, but will see time at the track as well. Would like to run 10.0 and stay on pump gas. Looking at a 540 aluminum head roller motor and we want to start with a new block.
    What are your thoughts? Dart, Merlin? I'd really like to try and get the owner to step up to an aluminum block, but I'm not sure if that's in the cards. As usual, price is important, but not everything.
    TEN THIRTY ONE RCB19's Avatar
    Dart makes a nice product. I've seen a few out of the box nightmares with the Merlin stuff.
    RCB
    Nov 2008
    Orangevale CA
    Quote Originally Posted by RCB19 View Post
    X2..... I have had good luck with a Dart (Iron 496 ),Blown alky Hydro.........Eric
    Senior Member CNC BLOCKS's Avatar
    Sep 2009
    X2 as we have seen to many problems with the World stuff
    Brodix aluminum is fairly cheap and good.
    Peoria, AZ
    For a cast iron block the Dart "Big M" is our first choice!
    http://www.hotrod.com/howto/113_0206.../photo_02.html
    Quote Originally Posted by The Doctor View Post
    X3....World stuff is 4 the birds.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    X2 i think Brodix gets overlooked to many times on there products
    Peoria, AZ
    The Dart is a good all around block. Do not assume that just because it says Dart it is ready to run. I have had to straiten out the decks on the last three I have got. The last five all needed the mains fixed since they were way out of whack and you have to check the threads on every bolt and plug hole. None of the oil gallery plugs were tapped deep enough. Now don't expect any of the other blocks to be much better. The last CNC Bowtie blocks I got were a little better, but I have not got one of them in a while. I know the Merlin's were "hit and miss" over the last few years but I guess they went to a new foundry recently. It would be nice to see them putting out a great product again like they had with the Merlin Pro blocks.
    Moral of the story, expect to pay more since there will be machining you did not expect. I have no experience with the aluminum blocks so I can't say what they are like.
    Paul
    Sep 2009
    Here is what we do to a Big-M block when we machine them
    I deck all of them to a finished number depending on gasket & desired piston height
    Block needs to be honed with a plate or bored & honed depending on bore
    Bottoms of bores need to be chamfered
    Most need the lifter bores honed, at the least checked
    Most need line honing
    All pipe threads need to be retapped
    Oil return from fuel pump cavity needs to be done
    Core plug holes need deburiing
    CHECK THAT THE DISTRIBUTOR GEAR DOES NOT CONTACT THE BLOCK BY THE CAM. There is a big cast blob down there you may want to relieve.
    Mohave Valley/Quartzsite
    Have you seen problems with rings sealing because of cylinders moving around?
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Lake Havasu
    Aluminum Dart...
Name:	New CP Engine 003.jpg
    Quote Originally Posted by stix818 View Post
    not really and mine is at 4.600..
    have talked to guys running big n20 hits with bores larger than that and they are claiming not to have problems.
    the only extra machine work mine needed right from the get-go was on the mains. they were .003 undersized.
    other than that, i've been totally happy with my block.
    Gone
    Sparks, Nevada
    Ummm.....prolly left out a zero. .0003 ??
