Hilborn injection dizzy ?
Results 1 to 14 of 17
    Senior Member PRO53's Avatar
    TOMBALL, TEXAS
    Default Hilborn injection dizzy ?
    I am lookin at some parts for a crower injection unit I have and these distrubators are part of the package deal. Has anybody ever seen them and what do they do. All I know is I dont nee them to run my crower setup. Any info on these? I think they are for can am?
ID:	61908   Click image for larger version.
    OMEGA JET, AND Sanger Shovelnose Hydro
    "DOWN WITH THE SICKNESS"
    AND A LIST OF ONGOING
    Nov 2008
    Orangevale CA
    Quote Originally Posted by PRO53 View Post
    WOW It look's like you have a distributor - tack drive - fuel pump -barrell valve and fuel line's --all in one package --impressive , lol ,, not only that you have 3 of them , lol , I dont know where they were used but quite a set up..............Eric
    TOMBALL, TEXAS
    Quote Originally Posted by alkyexpress View Post
    I found out what they are they are a Lucas injection metering setup. Just found it on the Kinsler site. What the site says that it was used in can am alot. It meters the fuel to each cylinder through the dizzy and the metering device. I just found the picks on the web. Just wondering if anyone has ran one?
    I was looking for some crower injection tubes and the old boy says 500.00 for the package deal. It has two of the dizzys like in the picks a crower base only and about 3 sets of injector tubes. Just the tubes.
    Has anybody ran this setup before?
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    Just after WWII mechanical fuel injection was timed. All coming from Europe.
    Mr. Hilborn asked the question why with valves opening 25 times a second @ 6000 rpm & constant flow mechanical fuel injection was born.
    The rest as they say is history.
    I know very little about timed mechanical fuel injection. Just enough to know it is something I would never want to mess with.
    Funny though the dizzy's say Hilborn on them.........
    It is supposed to be hard, if it wasn't hard everyone would do it. The "hard" is what makes it great. - Jimmy Dougan
    It's a celebration bitche's - Rick James
    Akita's & Boats: http://s255.photobucket.com/albums/hh149/K-Morg/
    Ok....I'm retarted....so what...
    Quote Originally Posted by Cole Man II View Post
    Tony, Tony, Tony....
    If dragboats were gay, that would make you Harvey Milk...
    Well if you want to make up a bunch of numbers to be right, then yes, that works.
    Similar to a Bosch timed injector, except they used a timer run off the front of the cam and used a dedicated timing cover. I believe Racey on the boards here has a Bosch setup for a Late Hemi. Roger Finney of Finney Plastics in Havasu has one for a BBC. But I believe the are both Bosch. I know neither used the dizzy setup.
    TOMBALL, TEXAS
    Hey Morg, didnt you use to run a crower setup on your old boat? Did you like it?
    Yes I did.
    The crowers were my first adventure in fuel injection. They taught me so much. Great throttle response & easy to tune.
    I ran alky. I am afraid of gas, it stinks & is harder to tune.
    I still have them. Sure I will use them again some day...........
    Peoria, AZ
    You may want to contact Kinsler and see what they might give you for those units. I know they are BIG bucks to get through Kinsler, and that is for refurbished units.
    Paul
    Nov 2008
    Orangevale CA
    Paul
    X2 to what paul is saying,, you might have some good trading material to get the rest of what you need to run your other unit,, good find,, Eric
    Senior Member Hydroguy's Avatar
    Exactamento, you have the Lucas Dist. Those were used on the Can Am's. Kinsler gets a lot for them but that doesn't mean they will give you a lot for them.
    The Hat
    Guest
    those look like the Old "Tecalimite" injection fuel and ignition distributors, those were a timed injection and proved to be pretty good if you could figure them out and get the fuel curve the way you wanted it....
    TOMBALL, TEXAS
    Well here is one on ebay.
    http://cgi.ebay.com/ebaymotors/Lucas...item2c52562117
    Going to pick up the parts on Thursday.The dizzys the dude has says Hilborn on them.
    Senior Member MR.Magoo's Avatar
    hey pro i saw a injection set up in houston craigslist for 1000.00 .
    Nov 2008
    Orangevale CA
    These people are NUT'S ,, you can get that type of system for $1000-$2000 all over the place ,, they seem to work good,,, check the shaft's and linkage for play,, they can be a nightmare if it is loose,,,( trust me ) ,,, ...........Eric
