Block filler in a hot tank
Results 1 to 5 of 5
    Senior Member Ronboats's Avatar
    Norcal-Santa Rosa
    Default Block filler in a hot tank
    Is there any reason that a block with block filler should not be hot tanked? Is there any effect on the filler? Block is clean, but it had bearing shell shavings go trough it.Gonna hone it and ring and bearing it. (crank and rod have been repaired already)
    waterloo
    Should not be a problem.
    Run it through a spray washer.. like a big dish washer. (some shops call them both a hot tank) (most shops use a spray wash before final assembly, not a hot tank)
    Will not affect anything.
    Wags
    Our local shop used to have a HOT TANK (chemical tank) it would remove anything that was not metal on the motor, EPA has since forced them to use a washer system, using hot water.
    Somewhere between Paso & L.A.
    MY MACHINE SHOP has both a hot tank and a jet wash, the hot tank is for
    stripping everything off the block,( say goodbye to cam bearings) while the jet wash is like was said," a big dishwasher" for cleaning less dirty stuff
    Senior Member cakeeater ed's Avatar
    huntington beach ca.
    I had 3 tanks in my mach. shop, 2 "dish washers" one with "soap" for anything & one with caustic for c/I blocks & heads & an old school tank with a nasty solution of caustic for the flatheads, block filler should be expoxy & not be effected by anything in today's shops.
